Sticky speedometer and broken odometer
My speedometer has been sticky for a while, staying at zero until I reach about 25 mph. Once at that speed it seems to work fine. Now, I just realized that my odometer has stopped altogether. It's not adding any miles (top or bottom). I called up No Ho Speedometer and they would be able to fix this for about $150. Has anyone attempted this fix themselves? Is it even possible to do with DIY knowledge and tools?
My car's an '85 Carrera. Thanks all.
_______________ Henrik '85 Carrera Coupe Black on Black |
Black and Blue
sounds like your sender could have quit. also, it could just be corroded wires on the back of the speedo or even a loose or bad ground.
in any event, i would see if you could borrow a speedometer from somebody, maybe a shop could hook a spare up for a small fee. This would at least let you know if the problem is with your speedometer before you send it out for repair.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
I have the exact problem... Odo and Trip just stopped this week while driving. Speedo has been "sticky" for a few months... 85 Carrera
I have a speedo from a 77S but not sure if it is compatable to swap for a test. Please let me know if you have luck in diagnosing this. Having a very busy month and it's not looking as if I will have time to pull mine out. Thanks |
Mucho threads on this.....broken gear...a do it yourself for the ever-so-careful........
Otherwsie it's hands off to the pros at NHW speedos.. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Wow, this is interesting, tonight the odometer and trip-odometer stopped working. The speedo is fine (no sticking), but nothing else. I'll check the cables and grounds. I guess if all else fails, it goes out to North Hollywood.
Scott ___________________________ 1985 Carrera Targa - Guards Red 2006 Acura TSX Navigation - Milano Red |
