'83 911 SC (Hard Starting Problem)
My '83 SC is giving me some nagging problems. When I drive the car for 30 min - hour straight and then let it sit for a while...It takes forever to restart. It will turn, turn but wont start. I will floor it until I smell gas and then eventually it will roughly start. Once started, it will run smooth and fine.
Now, if I drive it and only let it sit for a few minutes (like in and out of a store)...no problem! The only thing that I can think of is...I had just filled up with gas prior to me really noticing this so I'm trying to run this tank down and refill (at another location) to see if this helps.
Any info would be appreciated.
Thanks!
Old 09-18-2009, 08:48 AM
Oh Haha's Avatar
Try some new gas first but most likely it is your fuel accumulator that's bad. It keeps fuel pressure in the lines so it is "there" when you go to start.
I don't believe that pumping the pedal is needed with fuel injection. The electric fuel pump negates having to do that.
I have always been instructed NOT to when started a fuel injected car.
Pacific Blue
Wayne
Old 09-18-2009, 11:02 AM
DDD DDD is offline
DDD's Avatar
Had the same problem with my '83SC two years ago. As suggested above, it was the fuel accumulator. Easy fix. Only posting to add another data point, and give you confidence that it is pretty easy to do. Good luck.
1983 Ruby Red Metallic 911SC
2005.5 Audi A4 2.0T Quattro
1991 Mazda Miata Special Edition British Racing Green
www.DDDinMN.wordpress.com
Old 09-18-2009, 11:24 AM
so where is the fuel accumulator located?
Old 09-18-2009, 11:47 AM
On the left side of the engine compartment behind the fuel filter.
Bob D
1982 RoW Silver 911SC - PCA E #339
1997 993 Turquoise Blue Carrera S
Old 09-18-2009, 11:51 AM
Oh Haha's Avatar
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_FULcis_pg2.htm#item6
Pacific Blue
Wayne
Old 09-18-2009, 11:58 AM
