-   -   New equal length headers (http://forums.pelicanparts.com/porsche-911-technical-forum/500557-new-equal-length-headers.html)
Larry_Ratcliff 10-11-2009 01:56 PM
It seems to me that a reasonable trade off was made. If the primary's were any longer then you would have to go with a muffler similar to the B&B. To me the fact that I can keep the muffler that I have is what makes them attractive to me. I am curious to see the dyno results with these vs others but I suspect on my 3.6 they will have to be better than the SSI's I have now. If you consider the length of the primaries on the SSI's these are surely no worse than that and benefit from what looks like a well designed collector and larger pipes. I am more than willing to leave a little mid range on the table to not have to redo my back bumper ....
I have found many times that the 'best' is often 2x (or more) as much and really does not deliver such measurable differences. I really doubt this system is leaving all that much on the table. Also, available with heat is a very nice feature.
I guess if you are a racer in a class trying to optimize the hp within the constraints of the class you run in then your goals are much different than a street performance car. I for instance would not spend 10K plus on head work on my car. However, a friend of mine trying to be competitive with his 356 spent over 10 K so he could have custom valve guides lightened valves perfect ports reshaped combustion chambers on and on... However, the $ spent vs just a port and polish from a shop like Ollies was a 5 x difference... I suspect the net difference in hp was about 5 to 10. I hope the comparison here makes sense.
I cant wait to see the heat exchanger version.
SmileWavy
911st 10-16-2009 03:01 PM
There has been kind of a hole in the market for a good header with heat at a reasonable price. SSI 1.5" headers leave a good 10 HP on the table for stock block 3.2's over SSI's or stock HE's with a cat bypass & sport muffler.
Larger tube B&B's are about the only other option and are expensive and many do not care for there mufflers ability to hold up and it dose not fit off the shelf Porsche Mufflers.
I suspect primary length is more important with carb style cams that have overlap where savaging can be a benefit.
With mild SC, Carrera, C2 cams the primary length dose not seem to be so important as there is not much savaging potential.
It is more about getting the exhaust out without the events colliding which is what equal length headers are about.
Per SW of 911chips.com a tuned 3.2 with 1.5" tubes and Phase 9 race mufflers and chip pulled 249fwhp. Larger headers with full race exhaust made 10hp more.
I suspect the key to success here is the quality, equal length, ability to use a stock style muffler, fair price, but most importantly effective heat exchangers.
RWebb 10-16-2009 03:08 PM
are you saying that a stock 3.2L motor with SSIs can have 10 HP more if using something else?
I am having a little trouble parsing your sentence structure above, but that is counter to what I've heard from people who have dyno'd thousands of motors.
911st 10-16-2009 03:32 PM
Sorry, I just got off a 9 hr jet ride.
There is a great comparison around here some where that SW did from many dyno runs.
911st 10-16-2009 03:38 PM
Here it is:
Originally Posted by Steve W (Post 4082599)
I've compiled a spreadsheet of expected power output values based on a internally stock 3.2 Carrera motor based on dyno tuning data that I've accumulated from many cars over the years. The output values are given in engine flywheel hp assuming a Superflow engine dyno such as at Jerry Woods. You results may vary, based on the flow quality of your muffler, but for a healthy 3.2 motor, I estimate these values to be accurate to within 2-3 hp of each other.
Also, there are a lot of dyno charts on 911chips.com
TimT 10-22-2009 05:25 PM
UPS left a set of headers on my steps yesterday..
The build quality of these is impressive. The slip joints will really help with ease of mounting.
I have to cut the stubs off my set since my engine has 38mm exhaust ports (small disp/NA) , and the o.d. of the pipe is 38.07mm or so..Got my old headers off in about 30 minutes.. So in reality you could get these installed in around 1-1/2 hours.. (if you have co-operative exhaust hardware, my engine gets torn down once a year so the exhaust nuts are easy peasy to remove)
Pictures comparing M&K headers with Narbel (on my newly refinished vertical grain Fir floors)
http://forums.pelicanparts.com/uploa...1256256793.jpg
http://forums.pelicanparts.com/uploa...1256256925.jpg
I had O2 bungs and v-bands welded on..
911st 10-22-2009 07:41 PM
Nice!
Any chance you can measure the length of the primary tube on each set?
Those shorties are just begging to go straight and have a turbo stuck on each one.
Larry_Ratcliff 10-22-2009 07:57 PM
those look sweet! I cant wait to see the heat exchangers.
mnmasotto 10-23-2009 10:33 AM
Realistic turnaround
If someone ordered a set in 1.625" today what would the turnaround time be?
Thanks Mark
TimT 10-23-2009 07:56 PM
This is a very good article on exhaust design....
http://www.n2performance.com/performance/exhaust-systems/index.htm
I ran the numbers on these headers... yeap with short primaries I give up bottom end..
ok... what 2.2 or 2.4 Porsche 6 has any grunt .. to begin with... btw I'm using these on a full race 2.4
TimT 10-25-2009 07:11 PM
Found a picture of the headers that were on our GT3RS at LeMans
shorties... the whole torque curve shifts right..
oops posted wrong picture
TimT 10-25-2009 07:13 PM
Porsche Motorsports headers..
http://forums.pelicanparts.com/uploa...1256523205.jpg
911st 10-25-2009 07:36 PM
Originally Posted by 911st (Post 4968302)
Nice!
RarlyL8 10-25-2009 08:50 PM
1.625" are in production right now. Each production run lasts a couple of weeks. There are 3 sizes available; 1.5", 1.625" and 1.75" for both 911 and 930.
Primaries are 17.5" +/- 0.25".
We are making a set for a twin turbo application as well. One aspect of the design is that it will accommodate other applications with a simple secondary pipe change.
1979911sc 12-28-2011 04:33 PM
Didn't see any of these headers available for a n.a. 911 on host's website... Are you still making them?
Pierre911SC 12-28-2011 07:17 PM
I just bought & received a set of 1 5/8 in. headers from him.
rarlyl8.com
RarlyL8 12-31-2011 06:04 PM
Yes we are still manufacturing these headers. Our host has not picked them up yet but probably will at some point. Power is enhanced in the midrange and top end without taking away from the bottom on 3.0L+ modified engines.
http://forums.pelicanparts.com/uploa...1325383035.jpg
http://forums.pelicanparts.com/uploa...1325383184.jpg
paulgtr 12-31-2011 08:04 PM
only as headers, or is their a similar set up as heat exchangers? running SSI's now and wonder if I am giving away top end. doing more track time now so running near redline is common.
RarlyL8 01-01-2012 07:45 AM
No heat exchangers for the 1.625" headers right now but we are working on it. The 1.5" and 930 headers now have revised exchangers that bolt-on.
paulgtr 01-01-2012 08:11 AM
I should hold off on any changes until the bigger headers have the option for H.E. otherwise the 1.5" are too close to what I have already, yes?
GaryR 03-20-2013 11:32 AM
Were any before/after dyno runs done on a stock 3.0 with the 1.625" medium length headers??
snbush67 03-20-2013 05:56 PM
My experience is that these headers will move your power-band up about 1500 rpm over the SSI's. So if your torque sweet spot is at 3700 it will move it up to 5200 and you'll top out around 7500 or so.
I added the quiet riot sensing auto baffles and restored lost low end after installing these headers without sacrificing top end.
My experience is based purely on drivers seat experience, no dyno testing was done, and no animals were harmed.
GaryR 03-20-2013 06:21 PM
Thanks, but I want to see dyno results as I run at 4000+ RPMs 100% of the time, but its on the track. I plan on having my car dyno'd before the 1st race at Limerock, hope to see good results!
RarlyL8 03-20-2013 07:12 PM
We have another system that will be dyno tested soon and will test these headers as well to compare. The two systems are for different applications so this should tell us a lot. There is always a packaging compromise and so far the medium length headers have done what we hoped they would do; give a good option to those with engines above 3.0L that need a simple system made of long lasting materials / workmanship that works with any dual inlet muffler. We like our mufflers but understand folks need options.
http://forums.pelicanparts.com/uploa...1363831857.jpg
GaryR 03-21-2013 04:30 AM
Very cool Brian!
