It seems to me that a reasonable trade off was made. If the primary's were any longer then you would have to go with a muffler similar to the B&B. To me the fact that I can keep the muffler that I have is what makes them attractive to me. I am curious to see the dyno results with these vs others but I suspect on my 3.6 they will have to be better than the SSI's I have now. If you consider the length of the primaries on the SSI's these are surely no worse than that and benefit from what looks like a well designed collector and larger pipes. I am more than willing to leave a little mid range on the table to not have to redo my back bumper ....
I have found many times that the 'best' is often 2x (or more) as much and really does not deliver such measurable differences. I really doubt this system is leaving all that much on the table. Also, available with heat is a very nice feature. I guess if you are a racer in a class trying to optimize the hp within the constraints of the class you run in then your goals are much different than a street performance car. I for instance would not spend 10K plus on head work on my car. However, a friend of mine trying to be competitive with his 356 spent over 10 K so he could have custom valve guides lightened valves perfect ports reshaped combustion chambers on and on... However, the $ spent vs just a port and polish from a shop like Ollies was a 5 x difference... I suspect the net difference in hp was about 5 to 10. I hope the comparison here makes sense. I cant wait to see the heat exchanger version.
There has been kind of a hole in the market for a good header with heat at a reasonable price. SSI 1.5" headers leave a good 10 HP on the table for stock block 3.2's over SSI's or stock HE's with a cat bypass & sport muffler.
Larger tube B&B's are about the only other option and are expensive and many do not care for there mufflers ability to hold up and it dose not fit off the shelf Porsche Mufflers. I suspect primary length is more important with carb style cams that have overlap where savaging can be a benefit. With mild SC, Carrera, C2 cams the primary length dose not seem to be so important as there is not much savaging potential. It is more about getting the exhaust out without the events colliding which is what equal length headers are about. Per SW of 911chips.com a tuned 3.2 with 1.5" tubes and Phase 9 race mufflers and chip pulled 249fwhp. Larger headers with full race exhaust made 10hp more. I suspect the key to success here is the quality, equal length, ability to use a stock style muffler, fair price, but most importantly effective heat exchangers. |
AutoBahned
are you saying that a stock 3.2L motor with SSIs can have 10 HP more if using something else?
I am having a little trouble parsing your sentence structure above, but that is counter to what I've heard from people who have dyno'd thousands of motors. |
Sorry, I just got off a 9 hr jet ride.
There is a great comparison around here some where that SW did from many dyno runs. Last edited by 911st; 10-16-2009 at 03:39 PM.. |
Here it is:
Navin Johnson
UPS left a set of headers on my steps yesterday..
The build quality of these is impressive. The slip joints will really help with ease of mounting. I have to cut the stubs off my set since my engine has 38mm exhaust ports (small disp/NA) , and the o.d. of the pipe is 38.07mm or so..Got my old headers off in about 30 minutes.. So in reality you could get these installed in around 1-1/2 hours.. (if you have co-operative exhaust hardware, my engine gets torn down once a year so the exhaust nuts are easy peasy to remove) Pictures comparing M&K headers with Narbel (on my newly refinished vertical grain Fir floors) ![]() ![]() I had O2 bungs and v-bands welded on..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 10-22-2009 at 06:06 PM.. |
Nice!
Any chance you can measure the length of the primary tube on each set? Those shorties are just begging to go straight and have a turbo stuck on each one. |
Realistic turnaround
If someone ordered a set in 1.625" today what would the turnaround time be?
Thanks Mark
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes 2006 M3 Competition Package 2007 997 GT3 - SOLD |
Navin Johnson
This is a very good article on exhaust design....
http://www.n2performance.com/performance/exhaust-systems/index.htm I ran the numbers on these headers... yeap with short primaries I give up bottom end.. ok... what 2.2 or 2.4 Porsche 6 has any grunt .. to begin with... btw I'm using these on a full race 2.4
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 10-23-2009 at 08:15 PM.. |
Navin Johnson
Found a picture of the headers that were on our GT3RS at LeMans
shorties... the whole torque curve shifts right.. oops posted wrong picture
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Navin Johnson
Porsche Motorsports headers..
Crotchety Old Bastard
1.625" are in production right now. Each production run lasts a couple of weeks. There are 3 sizes available; 1.5", 1.625" and 1.75" for both 911 and 930.
Primaries are 17.5" +/- 0.25". We are making a set for a twin turbo application as well. One aspect of the design is that it will accommodate other applications with a simple secondary pipe change.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Didn't see any of these headers available for a n.a. 911 on host's website... Are you still making them?
I just bought & received a set of 1 5/8 in. headers from him.
rarlyl8.com
Pierre stsrobotic@yahoo.ca 82 911SC wide body, 3.6L
Yes we are still manufacturing these headers. Our host has not picked them up yet but probably will at some point. Power is enhanced in the midrange and top end without taking away from the bottom on 3.0L+ modified engines.
just me
only as headers, or is their a similar set up as heat exchangers? running SSI's now and wonder if I am giving away top end. doing more track time now so running near redline is common.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
No heat exchangers for the 1.625" headers right now but we are working on it. The 1.5" and 930 headers now have revised exchangers that bolt-on.
just me
I should hold off on any changes until the bigger headers have the option for H.E. otherwise the 1.5" are too close to what I have already, yes?
