Throw it on the ground!
Intake Gasket Replacement Project with pics
Finally got around to this project after several months procrastinating. Engine miss/ rough idle when cold diagnosed as intake leak at cyl #2. I made pretty good time after work today. Got intake removed, gaskets and spacers replaced and intake reinstalled. Now just need to torque the barrel nuts, reconnect the fuel lines, oil breather hoses wire harnesses, heater fan, and air box. The hard part is done!
I got really lucky in that none of the gaskets stuck to the heads or intake manifold. They all pealed away easily which cut down on the project time.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 10-09-2009, 09:35 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Excuse me for asking but those gasket still look good. Did any of them actually leak?
I recall seeing a thread where a gasket was sucked in.
'85 Carrera Targa
PCA/POC
Old 10-10-2009, 12:13 AM
I was thinking I might find a sucked in lower gasket on #2 where my air leak was diagnosed (by the Porsche dealer tech) but both gaskets were intact. The upper gasket was wet with fuel as you can see in the pic which could be where the leak was. I will note that the barrel nuts did not appear to be properly torqued (i.e. too loose)
Mark
1987 911 Coupe
Old 10-10-2009, 03:43 AM
DRACO A5OG's Avatar
Very interesting, maybe I should check the torque on mine before diving into this. Is the torque settings in the Bentley Manual? if not can you post?
'85 Carrera Targa
PCA/POC
Old 10-10-2009, 07:20 AM
All done. Idle is now smooth as butter. Torque spec is 18. I'll re-torque in a week.
Mark
1987 911 Coupe
Old 10-10-2009, 12:55 PM
GaryR's Avatar
Send a message via ICQ to GaryR
I flat plated my spacers before putting the new gaskets on. A quick check showed they were far from flat so I figured better to have a flat gasket surface/seal than not..
Gary R.
Old 10-10-2009, 01:32 PM
vacuum leak
Was there a noticeable sound! like a whistle when you suck air in? Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 10-10-2009, 02:08 PM
No, not noticable at all. The Porsche tech ran some diagnostic tests and detectected something amiss at cyl #2. He changed the plug wires first then the plug itself with no change. He then sprayed some starter fluid aroung the intake port ( alot of it) and finally got a slight change in idle indicating an air leak. I had tried that previously and got no change in idle.
Mark
1987 911 Coupe
Old 10-10-2009, 02:30 PM
DRACO A5OG's Avatar
Damn, I am thinking that must be my mysterious Idle Issue. She runs great, It just at time she would drop RPMs then after a brisk drive all fine.
Thanks Mark, another To Do
'85 Carrera Targa
PCA/POC
Old 10-10-2009, 02:49 PM
My idle issue was worse when cold. When the car got up to operating temp it was hardly noticible but I always knew it was there. It improved when I tightened the barrel nuts but that was merely a bandaid. The spacers appeared to be in pretty good shape but I replaced them anyway. The gaskets were pretty hard and brittle. If you do this, replace the rubber boot that connects the two halves of the intake manifold - only about an $11 part.
Mark
1987 911 Coupe
Old 10-10-2009, 03:24 PM
DRACO A5OG's Avatar
So total cost not including the rubber boots?
'85 Carrera Targa
PCA/POC
Old 10-10-2009, 03:28 PM
About $65
Mark
1987 911 Coupe
Old 10-10-2009, 06:26 PM
That looks familiar. I replaced the barrel nuts on my car with nylon insert lock nuts. Two of mine had completely liberated themselves from the studs and were sitting on the shroud.
1987 GP White 930
1977 Ford Bronco
Old 10-10-2009, 06:41 PM
DRACO A5OG's Avatar
Originally Posted by mthomas58 View Post
About $65
Nice
'85 Carrera Targa
PCA/POC
Old 10-10-2009, 08:31 PM
Hi
Targa Me's Avatar
When i replaced my intake gaskets, I stuffed a rag into each port to keep debris and junk from entering while i cleaned the gasket surface.
Old 10-11-2009, 08:35 AM
