Noise Reduction
Does anybody have any recommendations on how to reduce engine and road noise inside 911?
Designer King
If you search this, you will find quite a few options. Some have used Dynamat or similar self adhesive products. Some have used rollon coatings. There is also the factory firewall pad for sale from our host. I've found even an additional floor mat or mat underpad makes a difference. And even the type of exhaust has a big bearing on noise. I also recently noticed that once I got my CIS engine tuned correctly (after having fixed the vacuum leak and WUR problem) the engine is a lot quiter.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Sound Deadening Materials for Noise Reduction from Second Skin
a layer of damplifier pro followed by a layer of luxury liner pro. use a layer of heat wave pro behind the rear seats and on the parcel shelf on top of that to help with heat. you may have to step down to the non-pro version of heatwave to get everything to fit under the carpet.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
AutoBahned
road noise?
tire noise? wind? what do you mean exactly? |
Recommendations also depend on your starting chassis - SWB, Long hood LWB, Mid-9, SC, Carrera, etc. Each has different levels of Factory stuff and respond differently to 'improvements'.
If I could have my original 2200# SWB or 'slightly' mod 1900# 914-6 as quiet an my 'heavy' SC sunroof coupe, I would. Mutually exclusive requirements. Keep in mind new 911s (even 997RS) can push 4000#. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
winter
I think what you don't need is less noise, but more! Get yourself some sort of aftermarket exhaust that's loud as hell so all you hear is your engine's siren song of amore!
![]() --- Tom '75 targa |
just me
ear plugs
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
The newer Porsches use something that looks like a closed cell memory type foam about 1/2 to 3/4" thick that form fits the chassis and works pretty well - much lighter than the old asphalt barrier and carpet pad type material used in the earlier cars. The stuff is white,, I'm not sure if it's a vinyl or urethane material. Check with the materials from Aircraft Spruce.
I think the only new 911s that push close to 4000# are the TTs with AWD, pushing 37-3800. However, no way though would a late RS or GT3 come in that high - wet with a half tank of gas normally comes in between 3180 to 3250, depending on options such as PCCB. |
AutoBahned
Steve - have you ever seen that new foam in a dealership parts area?
must be available for accident repair... |
N-Gruppe doesn't exist
i put on a one out exhaust ....but now all my early car friends make fun of me...
seems the gruppe i hang out with are part of the "LOUD PIPES SAVE LIVES" crowd
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
Randy, that stuff is bonded/molded together to the back of the interior carpeting - I know what you're thinking. You're not going to be able to buy factory carpeting to install it into a early car, even the carpeting sections are form molded to the shape of the interior. If someone could manufacture the same thing for the early 911, I think it would work very well and not be heavy.
AutoBahned
OK, thx Steve.
I will look for a 997 to sneak into and scrape their carpets... |
yeah, good luck - I'm keeping my doors locked around you!
