-   -   PMO/Weber filter element options (http://forums.pelicanparts.com/porsche-911-technical-forum/503885-pmo-weber-filter-element-options.html)
Pete000 04-29-2013 01:10 PM
New and Old lids. Not interchangeable.http://forums.pelicanparts.com/uploa...1367266254.jpg
ganun 04-29-2013 01:20 PM
Originally Posted by rbogh901 (Post 4942414)
And meanwhile, being basically a cotton element, what are the options for K and N cleaning solutions? Searches for K and N generally degenerate into discussions as to whether or not they are better than paper elements. I've used K and N cleaning, solution, cleaner, etc...
Ive been using 409 as the cleaner solution because the original K N sol smelled just like 409 to me. Still follow the instructions however, i.e. to only soak the outside of the filter while the solution is in a shallow pan, 1/4 " deep, when I lift the filter from the sol I can see the dirt fall away, then rinse from the inside out, dry and oil.
George
KTL 04-29-2013 02:10 PM
BTW just to add more hardware options, I recently ran across this Timmons Billet site.
Porsche
You can get some fancy brushed aluminum cover plates from them. A friend lives in Wichita and says Timmons is legit. Been in the racing business for many years and still around.
Mervo 06-13-2015 08:42 PM
Originally Posted by 911pcars (Post 5259530)
I suspect K&N spec'd their housing to their custom-sized filter for a reason. I performed a serious search a few years ago, and K&Ns designed these housings to fit only their filter. An alternate filter housing that uses off-the-shelf paper filters would be a popular item.
I believe these foam filters are available from GCA Industries (True Flow) in Scottsdale AZ.
True Flow Yellow Porsche Filter 1965-1973
Part Number 85212
http://forums.pelicanparts.com/uploa...1269634136.jpg
Sherwood
Can these still be purchased?
merv
RichardNew 06-14-2015 09:09 AM
ITG is a good choice.
Richard Newton
Mervo 06-14-2015 03:49 PM
Thanks Richard. I will see if they have the oval version for the early filters as above.
Cheers,
Merv
Eric_Shea 06-24-2015 02:04 PM
Has anyone successfully used a stock 70's style filter housing with PMO's?
rswannabe 06-24-2015 02:32 PM
You mean like this? Stock factory airbox with custom base plates for PMO 46's welded into the lower sections that attach to the carbs. I run a K&N filter in my housing and cut off the snorkel for better airflow.
http://forums.pelicanparts.com/uploa...1435181530.jpg
jmz 06-24-2015 02:36 PM
back about 20 years ago, I used to run a 4 barrel paper filter element that I reshaped to fit the weber bases.
Trog 06-24-2015 02:56 PM
PMO ITB's on '84 3.2 using backdated air box:
http://forums.pelicanparts.com/uploa...1435182952.jpg
rswannabe 06-24-2015 03:07 PM
Trog - very nice! I have plans for that in my future. I want to go to EFI ITB's, but use them with the old airbox. Easy to do with the PMO ITB's.
Eric_Shea 06-24-2015 04:57 PM
Thanks Brooke!
Can the existing bases be modified on a drill press vs welding? I'm at Parade so I can't get my eyes on this and I'm looking for options for my mechanic.
911pcars 06-24-2015 05:58 PM
Eric,
AFAIK, the bases for Webers (maybe Solexes too) have the same screw hole pattern to the carb top (same as the velocity stack mounts). However, the lower "bathtub" portion of the AF housings are different and must be used with the correct upper section. The shapes are slightly different with clips in different locations. IOW, top and bottom portions must be compatible.
Fishcop 06-24-2015 10:16 PM
The Fabspeed airbox cover (painted satin black) is a nicer/quieter alternative than just cutting the snorkel too...
http://forums.pelicanparts.com/uploa...1435209327.jpg
rswannabe 06-24-2015 10:48 PM
Originally Posted by Eric_Shea (Post 8681947)
Thanks Brooke!
Frankly I do not know if you can just cut a few more holes in the bottom of the weber "bath tubs" to get them to bolt up to PMO's. I didn't try that.
rswannabe 06-24-2015 10:49 PM
Hmmmm. I'll have to give that a try to see how it compares to my snorklectomy.
