Front not level
Hi Guys,
I have looked everywhere bit have come to the conclusion I am not using the right search parameters. I recently had all of my shocks replaced but noticed that the left drivers side is an inch lower than the right front. I remember reading that this can be adjusted. I have an 86 Carrera Coupe. Does someone know the procedure for this, and anything else I should know with regards to this. Pics would be really helpful. Thanks guys. |
muck-raker
yikes, something's not right...was it an inch lower prior to replacing the shocks?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Recreational Mechanic
Front end ride height is adjustable via the tension bar adjustment. Search for ride height adjustment and you should find a how-to.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Thanks for the replies. yes it was like that before the shock replacement. I will have another search around the forum
There might be more to it than cranking down (or up) the torsion bar jacking screw. This is like trying to level a refrigerator by only adjusting two feet. You could conceivably get the front level and completely honk up the rear.
Here's the front adjuster: ![]() To get it right, I think you need to do a little measuring and make sure the tub is square and plumb. Ideally, when a level is run through two front suspension pick up points (right & left), a level run through two rear suspension pick up points should also be level. If not, you're going cork screw. Then you can measure an X under the car from pick up points. If the measurements aren't the same, you've gone trapezoid. It's possible to be both corkscrew & trapezoid at the same time. They are not self canceling. My experience is you then take the good parts home and leave the tub in the dumpster at the track. If you're square & plumb, then you can align, either at home or at a pro shop. |
