North Coast Cab's Avatar
M14 Flared Fule Hose Fitting
I need to find a barbed end M14x1.5 fitting for a fuel vent line on one of my cars. Porsche no longer makes the line.
Anyone have any ideas? It is a 10mm vent line that has frayed. It has a hose clamp on one end and an M14x1.5 female fitting on the other to connect to a hard line. I am trying to avoid splicing into a 30 yeard old rubber line.
TIA
1985.5 944 GTS
Old 10-20-2009, 05:30 PM
Almost Banned Once
sc_rufctr's Avatar
Can you post a picture of the hose please.
- Peter
Old 10-20-2009, 05:32 PM
Southern Class & Sass
Dixie's Avatar
Try BAT Inc.. They're in Sarasota. They carry Mocal metric AN fittings and adapters.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-20-2009, 05:53 PM
DW SD's Avatar
I'd propose changing the rubber at the same time. Use rubber or braided stainless hose from Earl's. Why chance a fire hoping 30 year old rubber will hang together?
Pelican has nice braided german vent line, too. It might be 8mm in size.
Doug
1971 RSR - interpretation
Old 10-20-2009, 05:57 PM
I have them, if our host doesn't offer them... Bruce
87 951 (All stock commuter)
87 951 (Saturday night Special)
77 911S (token tail dragger)
83 928S (engine back in from tear down, interior gutted)
....Grasshoppah
Old 10-20-2009, 09:15 PM
HarryD's Avatar
TIA
Go to a shop that makes hydraulic hoses.
They may have the fitting already or they can make it by cutting two fittings and brazing the two halves you need together. If you like, they can even swege on a rubber line to eliminate the clamp. They should be able to supply replacement gasoline compatible pressure hose as well.
Should cost you less than $20.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-20-2009, 10:30 PM
Here's what is look like. I can splice into the rubber with new line, it' the clamped end that is messed up, but I'd rather avoid that. Also, the rubber is real brittle. It is a female M14x1.5 flare fitting.
I looked at BAT and Pegasus and no luck.
F18Rep,
Do you have somehting that would work? Please PM if you do.
1985.5 944 GTS
Old 10-21-2009, 05:51 AM
HarryD's Avatar
If you have the part, like I said before, go to a local hydraulic shop. They will get you fixed up with fresh rubber sweged onto your old fitting in 15 minutes.
Harry
2020 MB E350 4Matic
Old 10-21-2009, 08:00 PM
Visit your local hydraulic shop.........
Bring your fuel line with fittings and they could easily fabricate a replacement fuel hose under $20. I had one made for me with new metric fittings approx. 36 long and cost me under $20. PM me, I might have some extras at home.
Tony
Old 10-21-2009, 08:18 PM
Walt Fricke's Avatar
Do you want another barbed M14x1.5 female flare fitting, so you can have one on each end of the new line you are making? I think what you want may be here:
DIN3853 Male Light
Or do you just want to make up a new line with just one end with a fitting? If that, why not do what Harry suggests?
Walt Fricke
Old 10-21-2009, 08:22 PM
Cooper911SC's Avatar
I'll 2nd or 3rd ...using a hydraulic hose place. I had "Hoseman" out here in CA put together new lines for my SC. I bought the BMW high pressure hose from Pelican and took it to the shop. They did the whole job in under an hour for $50 or so. The just carefully grind/cut off the old ferrels and then re-use your fittings with the new rubber hose.
I did have to look around a bit for someone who would do it...several shops didn't want the "liability" because there swaging dies weren't able to do metric fittings...c'mon think of all of the metric stuff on Hyundai forklifts you've probably done...whatever.
You will be much safer with new rubber.
My .02, Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 10-21-2009, 08:29 PM
BoxsterGT's Avatar
Porsche Crest
Which barbed hose end do you need?
Is it like this.............
The female barbed fitting above costs $5 plus postage.
I recently made up this fuel filter adapter for a 73 T w CIS.......
I have a complete line of Porsche fuel & oil fittings and METRIC braided hose, and make up custom hose assys to order.
Len at Autosportengineering dot com
Old 11-03-2009, 09:47 AM
Gillies's Avatar
Len, would you have a catalog or a list of all the lines available ??
Gilles...
1970 Targa 911T
Old 05-27-2010, 07:09 PM
BoxsterGT's Avatar
Porsche Crest
I do not have a catalog, but have most of the fuel or oil fittings needed on a Porsche.
Some special fittings I have made locally.
Best is to email me w thread size & dimensions & a photo of the hose or fitting you need.
Please no PM's as my box is almost always full.
Have a great Porsche day.
Len
Old 05-29-2010, 04:55 AM
