heiliges blechle!
I don't know what the previous owner used, but it probably wasn't synthetic. I put synthetic in it. The synthetic did a good job of cleaning out the gunk in the engine, but I think that is one reason the leak has gotten worse. The first oil change there was a ton of moly-looking stuff on the drain plug, the second change a couple of months later looked better but still had traces of moly. When I did the valves, it was cleaner than I could have imagined. It took 4 years, maybe 4K miles, but now the leak is getting worse. The oil looks great but possibly it has cleaned out all the stuff that was plugging the leak lol. I've been looking for an excuse to do my first engine drop.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 10-26-2009, 08:21 AM
Old 60's Porsche Tech
captainlewis's Avatar
eos part number is 88862586, about burning yourself with 21o degree oil. Put a wrench on the plugs and lossen them, Put a long extension with a ujoint 15 mm socket and finish removing the plugs at a distance. They will fall in the oil but can be removed with a magnet. This will leave your hands in tact. JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 10-26-2009, 09:15 AM
Make Bruins Great Again
Por_sha911's Avatar
Originally Posted by captainlewis View Post
Use any synthetic that you like and add gm eos one pint per oil change. Your zddp will be right on the money. Synthetic oil does not cause oil leaks, leaking gaskets and seals cause oil leaks.... If you dont want to mix use 20/50 mobil one for 4 stroke motorcycles and you will have the same thing.
Why pay double the money for synthetic and then pay to add Zddp if there is no benefit? Also, lest we forget, some of those 4 stroke MC or racing oils don't have all the additives needed. Your motor was designed for 20W50 dino oil with boatloads of Zddp and Brad Penn fits the bill.
Having said that (and will all due respect to the very knowledgeable people on this board): Religion, Politics, and Brand of Oil. You'll never change someone's mind.
Joe
Old 10-26-2009, 02:38 PM
1974 911 w/ 83 SC engine
I'm not against Brad Penn oil--and I'm sure it's great--but I wouldn't know a quart of it if I had two girls oil wrestling in a kiddie pool full of it in my front yard. Never seen the stuff, can't get it anywhere in Austin, and frankly having to special order oil over the internet doesn't save me a dime when they charge $25+ to ship a case (on top of waiting 10 days for it to show up). When Brad Penn finds its way to Austin, I will be first in line. Til then, this $9 a bottle full synthetic Royal Purple will have to do.
Old 10-26-2009, 03:20 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
search function comes to the rescue
brad penn in austin texas
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 10-26-2009, 03:30 PM
19 years and 17k posts...
azasadny's Avatar
I've been running AMSOIL 20W50 in the 911 and Swepco in the gearbox for almost 3 years and I change it and the Mahle filter once a year. I put 4k miles on it and store it in the winter. I run AMSOIL 5W30 in my 2010 MazdaSpeed3 and AMSOIL 75w90 in the gearbox of the MazdaSpeed3. No problems or leaks. Engine temps are 10 degrees lower than when I ran Castrol 20W50 in the 911.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-26-2009, 03:33 PM
Thats whats cool about Royal Purple( you could tell)... Thanks for the vision. Some one photoshop...
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-26-2009, 04:18 PM
brads911sc's Avatar
I wouldnt. No reason to.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 10-27-2009, 05:58 AM
I get my Mobil1 V-twin at Auto Zone in Austin on Burnet By the case
they have it every time or will get it by next day
Old 10-27-2009, 06:11 AM
(the shotguns)
berettafan's Avatar
i use the valvoline vr1 20/50 as it advertises increased zddp.
anything else i might say on the subject is just repeating what i've heard others say/claim.
Old 10-27-2009, 06:15 AM
Send a message via AIM to morrisjm1 Send a message via Yahoo to morrisjm1
I used to use Castrol 20w-50 and it was fine, except I had a hard time get around to changing the oil every 3000 miles. Much over 3000 miles and you could see, on the oil see the oil breaking down on the pressure gauge. At the same temp and RPM the oil pressure would be every so slightly lower than before, a needle width maybe. I switched to Royal Purple 20w-50 and even after 7000 miles, the oil pressure is unchanged. I consider it cheap insurance. It's a daily driver and I'm on the raged edge of lazy so I like having a oil that is still with me, even if I let it go a while. It also runs a little cooler too.
Mike
'78 911SC Targa (SCWDP member #17)
'74 MGB (one owner)
Pickup
2013 Ford Explorer Sport
2013 VW Golf TDI
Old 10-27-2009, 06:29 PM
Mike
This is exactly the situation I'm in, running Castrol but switching to Royal Purple--and if it really does run cooler with synthetic, which frankly I didn't think was possible, that single fact would be worth it. In the 100+ heat here in Austin my car sees 220+ degrees on a normal drive. Now, all I have is the carrera trombone oil cooler, but still 220?! Anything would help.
Old 10-27-2009, 07:32 PM
How did you know it was fine?
Old 10-28-2009, 05:33 AM
It's an assumption: 31 years old, 214000 miles, daily driver, runs great, sees the red line at least once nearly everytime it's driven, 1 bar+/1000 rpm oil pressure...I don't know seems fine.
'74 MGB (one owner)
Pickup
2013 VW Golf TDI
Old 10-28-2009, 05:50 AM
(the shotguns)
berettafan's Avatar
not sure that running the oil that produces the highest 'oil pressure' reading at the sensor is necessarily the right choice.
any thoughts on this?
Old 10-28-2009, 05:53 AM
I think investors with Madoff thought things "seemed fine" too. You haven't read the oil thread have you?
Old 10-28-2009, 05:54 AM
Almost Banned Once
sc_rufctr's Avatar
Pure and simple.... Synthetic oil is over rated!
I have used synthetic oils in the past but I keep coming back to Dyno.
Why? Because it works and it costs less.
Don't get sucked into the marketing hype.
(I change my oil twice a year regardless of mileage)
- Peter
Old 10-28-2009, 06:02 AM
EMT/TechRescue Instructor
86911cab's Avatar
I am on my first Brad Penn oil change. I have higher engine temps and higher oil consumption. I think I'll try something else. Maybe Castrol 20/50 with GM EOS
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 10-28-2009, 06:13 AM
brads911sc's Avatar
I use Kendall GT1 20w50. It has the right additives. is $35 a case. is Dino. use a qt every 1k miles. my engine looks like it was just polished inside when i do my valves. its also bone dry. my reason for not switching is that if its not broken, why fix it. I change my oil 1x a year... drive 2k miles... Most of the 20w50 oils are ok because the wear reduction rules dont apply to 20w50. some are better than others. Id stick to Kendall, Valvoline, etc.
Old 10-28-2009, 07:18 AM
"I think investors with Madoff thought things "seemed fine" too. You haven't read the oil thread have you? "
Well, I guess if you think my oil temp and pressure guages are in a conspiracy to defraud me maybe things aren't fine, but they do "seem fine." I think they’re giving me accurate info and I know Bernie has never driven my car.
I have perused the oil threat, it is kind of long and confusing, but I'll give it another look.
I’m not bashing dyno oil or praising synthetic oil. I’m just relating what I have experienced. I’m not talking about the oil with the “highest” oil pressure, I’m talking about oil pressure staying in the normal range for a longer period of time (mileage); over twice as long. If I could get around to changing my oil every 3000 miles, I would have probably stuck with Castrol GTX.
'74 MGB (one owner)
Pickup
2013 VW Golf TDI
Old 10-28-2009, 07:37 AM
