Michelin Pilot Exalto Tire puncture problem and options help needed
’89 stock Targa
Right Rear
225/50/ZR16/92W
Tire date 4306 (both rear tire)
I picked up a screw just at the end of the tread and where the sidewall meet.
Discount tire guy says can’t be fixed b/c it is outside the belted area.
All four Michelin Pilot Exalto tires are ’06 vintage with what looks to me as a lot of tread life left in them.
I am trying to weigh my options:
Should I get a second opinion of fixing the puncture?
Can I fill the tire with goo and expect it hold air normally, last and perform up to spec?
Would a new tire replacement for the one tire be a problem due to different tire tread thickness?
Would it be possible to find one slightly used replacement?
If it comes down to it, what tires would others recommend? Anyone run bridgestone portenza?
Thank you.
Cloud89
Old 10-27-2009, 08:28 AM
twistoffat's Avatar
I wouldn´t mxi tires on the same Axle. If they cant fix it then treat yourself and change the two. As far as recommendations are concerned then have a look at this
Tires?
Old 10-27-2009, 08:36 AM
AutoBahned
RWebb's Avatar
once fixed it will no longer have its speed rating
Old 10-27-2009, 08:55 AM
Monkey Butt Forespin
84_Carrera's Avatar
I've done borderline patches before on everyday drivers. I would NOT do this on a car that's expected to corner - you're putting stresses right at one of the critical spots, at the interface between tread & sidewall. I would also not mix tires. I have less of an issue with the same tire left / right with up to half tread left on one side, if you can find the same tire somewhere, but ideally, replace them both.
Good luck!
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 10-27-2009, 08:57 AM
Northern Motorhead
wildcat077's Avatar
Too bad we live so far apart... i have a set of four Michelin Pilot Sports 205/55/16 and 225/50/16's with only 600 kms that i will be selling,they were on my 89 Coupe when i bought the car and i upgraded to larger wheels and tires all around !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-27-2009, 09:25 AM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
Love my Bridgestones far better than the G-force they replaced.
Old 10-27-2009, 09:39 AM
Thanks all!
Looks like fixing is out of the question...
So it wouldn't necessarily be weird or unwise to replace the rears with something other than Michelin Pilots (that would still be on the fronts) for budgetary purposes until I can afford to match up the fronts.
I assume tread thickness front axle to back axle would wear differently anyway even if all corners new at same time, so newer front tires in a few hundred miles wouldn't be an issue. Correct?
Is it common to run different manufacturer tires between front and rear on the street?
I've been told that a softer tire other than the Pilots would make me happier since I think the ride is too rough, I always feel like I'm riding on a suspension of granite. I also plan to replace the stock Boge with regular Bilsteins. I'm not a track guy, just want a good quality tire so I can ultimately get as smooth and quiet of a tire and suspension ride as possible.
Old 10-27-2009, 10:17 AM
I've read many jacking possition threads and have the 101 book, but still confused about where to jack up my '89 that doesn't have a sump plate and would rather not have to use the side jacking points. Can I use soft wood blocks and place them either side of the seam roughly where a 911 with a sump plate would be?
Old 10-27-2009, 10:22 AM
are we anal about the manufacture week/year matching up, at least per axle?
Old 10-27-2009, 10:42 AM
84_Carrera's Avatar
Keep in mind if the tires you put on grip differently (cold / warming / hot) than what you had on there, your handling will necessarily be different than what you are used to.
Yeah, I got a year on the Kumho MX out back, and the fronts were in far better shape when I pulled those wheels. I think that's how a lot of guys go - 2 pairs' worth out back for one pair up front.
Fred Hurder Jr
For Tech Questions:
Old 10-27-2009, 10:44 AM
Richard Burns's Avatar
Do not fill your tyre wwith goo. It will stuff your rim.
Richard.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 10-27-2009, 10:49 AM
Found used one on ebay $40 + $20 (S&H)
Looks to be close to my tread wear, I will confirm.
Do I need to confirm if it's was used on left or right side?
Would I be crazy to buy a used tire from ebay?
VYC_bestusedtires out of Allentown PA, anyone ever dealt with these guys?
Old 10-27-2009, 11:17 AM
Make Bruins Great Again
Por_sha911's Avatar
Buying a used tire on ebay? You could be getting one that was flat-spotted, is out of round, or has broken belt. IMO, there are some things I won't skimp on: safety is #1 and 2. Tires, brakes, electrical and fuel all fall into the safety category. If you decide to buy the tire, there is a nifty little tool that measures tread depth (every tire store uses them). Get yours measured across the tire and ask the seller to measure theirs.
Joe
Old 10-27-2009, 03:46 PM
84_Carrera's Avatar
For $40, the seller isn't buying anything. Use a penny, with a digital pic, get the manufacturer's date code off the side of the tire & compare with yours.
Sometimes the budget needs to speak. Ideally, yeah, replace both with new, but there's something to be said for $100 bought, shipped, mounted, balanced vs. $350 bought, mounted, balanced.
If you decide to go the used route, best of luck!
Fred Hurder Jr
For Tech Questions:
Old 10-28-2009, 08:29 AM
I've had a set of Conti WinterSports fitted for a year that I bought from Evil Bay. Discount for nearly-new take-offs was hard to beat.
Get it/them inspected thoroughly by someone who knows what they're doing before mounting and you should be fine.
I always try to replace tires as a set of 4, if due to wear - they start to behave very differently as they age/harden, I think.
'77 S with '78 930 power and a few other things.
Old 10-28-2009, 11:44 AM
Ad says 6-7/32 tread left. Wear bars easy to discern in pics so I can compare
Date code year is '06, can't see the week of manufacture from the pics.
I will ask them for entire code.
Tire does look ok to my untrained eye in the pics.
If I buy, I will take the advice of having it checked out before mounting.
14 day return policy.
Thanks for all the help!
Old 10-28-2009, 04:33 PM
Decided not to compromise a go with 4 new.
Possibly yoko s.
Thanks again for all replies.
Old 10-30-2009, 07:48 AM
do we trust tire shops or should we order and have our preferred independent mount and balance?
thanks.
Old 10-30-2009, 11:48 AM
maclaren65's Avatar
Did you get the Yokohama S.drive?
Yokohama S.drive
Richard
'87 Grand Prix White 911 Carrera
Old 12-05-2009, 12:12 AM
