Northern Motorhead
wildcat077's Avatar
Fikse offset numbers ???
Hey guys,
Does anybody know how or where to find the offset reference on a Fikse wheel ?
The numbers on the wheels are : F116A11 2199 6744
F116A11 1399 6338
I'm guessing the first digits in the second series of numbers would indicate the offset,can anybody confirm this please ???
Thank you !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-29-2009, 09:29 AM
Registered Abuser
MT930's Avatar
Email Fiske they will tell you what the numbers mean.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 10-29-2009, 10:16 AM
Non Compos Mentis
Those are Fikse's serial numbers. They will tell you the offsets if you ask.
Old 10-29-2009, 10:37 AM
Don't know if you guys know, but FIKSE has shut down.
Old 10-29-2009, 11:21 AM
Registered Abuser
MT930's Avatar
Really ?
MT 930
американский
Old 10-29-2009, 12:22 PM
Navin Johnson
TimT's Avatar
Fikse closed shop, left some people in the lurch...
'69 911 GT-5
'75 914 GT-3
and others
Old 10-29-2009, 12:24 PM
Northern Motorhead
wildcat077's Avatar
This is the reason why i am asking on this Forum...
There is no reply at Fikse and i was hoping somebody more familiar with Fikse
wheels would be able to shine some light on those numbers.
I have my eye on a used set that i want to install on my 89 Coupe and the seller is unsure about the offset. It is a costly mistake if they do not fit properly... lol
Phil
Cheers
Phil
Old 10-29-2009, 12:29 PM
Bill Verburg's Avatar
Here is how you measure wheels
Bill Verburg
Old 10-29-2009, 12:47 PM
175K911's Avatar
I don't think those manufacturing numbers will relate to the size or offsets. I just looked at the serial numbers for my Fikse wheels and there's no relation whatsoever. Sorry. I think you're going to have to measure them.
Best thing you can do is find out what the seller had them on. If they were run on any 911 SC or Carrera from 78 to 89, they should fit your car too. The common Fikse offsets for our cars in 17" was et30 or 32 front and et 15 or 19 rear. But it depends on whether the fronts are 17x7.5 or 8.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 10-29-2009, 12:51 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
trying to find what size and offset will fit my car. I have a 1975 with SC flares out back. 17's will fit right? what width and offset are optimal?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 05-08-2010, 03:24 PM
Northern Motorhead
wildcat077's Avatar
Paul,
I 'm using Fikse FM10's this year due to a brake upgrade,they are 7.5 and 9.0 inches wide and i will go in the garage tomorrow morning,after the F1 race... and measure the backspacing for you.
I'm using 1/2 inch spacers in the front but that is most likely due to the modified hubs i had to install for my 996TT brakes.
My car is a narrow bodied 89 Carrera Coupe.I have 225/45/17 and 255/40 /17 Dunlop DZ1tires on presently and i could have easily went with 235's and 265's ...
Cheers !
phil
Cheers
Phil
Old 05-08-2010, 03:49 PM
just me
paulgtr's Avatar
you have no issues with rubbing? I have 205/55 and 225/50 on 16 inch fuchs. I had to roll the fenders to keep them from rubbing
Old 05-08-2010, 03:52 PM
Northern Motorhead
wildcat077's Avatar
Paul,
My previous setup was with 8 inch 951 offset Fuchs with 225/50 16's in the front and 9 inch Fuchs with 245/45/16 inch Toyo T1R's in the rear.
No issues whatsoever with the rear but i did slightly roll the front fender lips with a baseball bat before i got the 951 offset Fuchs as i had some rubbing with the stock 7 inch wheels ...
With my Fikses i'm using 1/2 spacers in the front and i have no rubbing issues,i could run without spacers but the inside of the spokes on my wheels are a little too close to the calipers,
I have 1/4 and 3/8 spacers spacers that i will play with after i do a final lowering and corner balance ...
Will get you the info tomorrow !
Cheers !
Phil
Cheers
Phil
Old 05-08-2010, 04:13 PM
Pre Registered
tchanson's Avatar
Not quite. Fikse was purchased by Kodiak several months ago. Fikse is and will continue as a separate line, and they just hired a new sales director for Fikse, a guy previously with Kinesis.
Tim
Old 05-08-2010, 04:29 PM
Northern Motorhead
wildcat077's Avatar
Paul,
Here you go,i got some numbers for you ...
1- Rear 9 inch 17" Fikse, backspacing 6 inches
2- Rear 9 inch 16" Fuchs, backspacing 5 1/2 inches , ET15
3- Front 7.5 inch 17" Fikse, backspacing 6 inches
4- Front 8 inch,951 offset 16" Fuchs, backspacing 5 1/4 inches , ET23
So it seems like my Fikses have the same ET,there is a formula for converting backspacing to ET somewhere in these forums,but at least this gives you a better idea !
Cheers !
Phil
Cheers
Phil
Old 05-09-2010, 09:12 AM
just me
paulgtr's Avatar
thanks a million,
so the fikse wheels locate the tire a bit more inboard than the fuchs if I am reading that right. so it allows wider tires for the same wheel well. are there any issues of rubbing against the inner fender well or rear oil lines?
Old 05-09-2010, 09:44 AM
Northern Motorhead
wildcat077's Avatar
Paul,
Always happy to help
No rubbing issues whatsoever,front or rear and like i mentioned earlier i could have went with 235/45/17 and 265/40/17 tires.Dunlop makes those matching sizes in their Direzza DZ1 Star Spec tire,which i think highly of so far !
As far as the wheels being located more inboard,that's a bonus as it's easier to space them out than having to bring them in ... lol
Cheers !
Phil
Cheers
Phil
Old 05-09-2010, 10:10 AM
just me
paulgtr's Avatar
when I went to lime rock for my first DE day, my instructor was running fikse wheels and the dunlops as well. his car was similar to mine with maybe stiffer dampers the only difference besides the wheels and tyres. he took me for a ride and you could really feel the difference in the way he could lean on the tires. of course I have much harder tires in comparison and I need to learn a lot more about driving, but it was such a huge difference in feel
Old 05-09-2010, 10:38 AM
The Fikse's I've seen on a 911 w/ SC/Carrera flares are
8x17 ET31.3
9x17 ET18.6
these fit well
in front you can use 8 ET25-31 fairly comfortably w/ 225 -245 tires, the 235 & 245 tires will need a lot of work to clear the fender lips at lower ride heights. ET25 sticks more out board than ET31
in back the 9s are a comfortable fir w/ 255 -275 tires. As w/ the front the wider tires get harder to fit the lower the car. and you will sometimes need to mod lips & trailing arm bolts and move oil lines
I used 8 235/45 x17 on 8 ET25 and 275/40 x17 on 9.5 ET19
just my opinon but 8 ET30 w/ 235/35x18 & 9 ET18 w/ 265/35 x18 would be a great combo and easier to deal w/ than the setup I had because the tires are shorter
Bill Verburg
Old 05-10-2010, 07:24 AM
Northern Motorhead
wildcat077's Avatar
Bill,
One question regarding the ET on my 7.5 and 9 inch Fikses.
Since the inner barrel on both wheels is the same with a backspacing of 6 inches would that mean that they are both ET 18.6 ? My front wheels are spaced out 1/2 inch in order to clear my calipers and Steve Timmins modified hubs...
The only difference is the outer lips which are 1.5 for the fronts and 3.0 inches for the rear !
Regards !
Phil
Cheers
Phil
Old 05-10-2010, 09:21 AM
