LinkBack | Thread Tools | Rate Thread |
Carrera speed/reference sensor replacement - partial drop required?
Getting ready to replace the two Speed/ Reference sensors (ones at front near tranny bellhousing) on the Carrera and was wondering if a partial drop is needed, or if there a technique for doing it without? Also going to replace cylinder head temp sensor as well.
Thanks.
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
Relatively easy to do. Work ref sensors out slowly. Use a wood stick or dowel to work grommet back in.
CHT, just clip wire and use a socket. Requires removing LR Wheel and jacking up car, that's about it.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
It is a good idea to replace sensors & cylinder head temps sensor all at once. I went ahead and did my O2 sensor as well. All of them had been in there for years.
You do NOT have to do a partial drop. You have to have strong fingers and patience. It ain't fun but it should not take more than an hour. Put some grease on the rubber grommet to get it back into place.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thanks fellas!!!!
Green Skull 006
As others have posted you don't need to drop the engine, but you do need to modify a deep socket (I'll have to check which one) by cutting a slot for the wire. IIRC I also had to bend the engine tin a bit to get something in or out. It was a while ago that I did mine.
![]() There are some pretty good threads regarding changing the sensors that will save you some grief if you do a search first.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
Green Skull 006
It's a deep 14mm socket that I made a slot with a grinder for the wire.
Checked out
As said above, no engine drop necessary.
I agree, it's a good time to also do the CHT sensor, ESPECIALLY if your car still has the old 1 wire style CHT sensor. You don't need the slot grinded socket for the speed and reference sensors, you do need it for the CHT. (Some people do it without, but cutting the wire on the old one, using a regular socket to get it out, then using needle nose pliers to put the new one in. I wouldn't be comfortable with that, I don't think you could tighten it enough with needle nose). Also, the CHT sensor can be either 14mm or 13mm. I just did my car, and the old one was 14mm (single wire), but the replacement, 2 wire version was 13mm. |
muck-raker
don't forget to add a smidgen of anti-seize compound on the threads of the new CHT sensor during install.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Thanks. It's this kind of info that makes all the difference in the world when doing these projects.
I seem to remember some people having problems getting their CHT out and it was recommended to not clip the wire right off just in case you run into trouble.
'85 RoW 911 Coupe '65 356 SC '72 BMW 2002Tii '10 Cayenne '20 Ram Longhorn |
muck-raker
It's actually probably easier to clip the wire. It's true that the CHT sometimes may be "seized" in the hole, and may need liberal use of PB blaster or whatever. But with the wires clipped, it's easier to get a good grip on the sensor itself. IIRC, you need a 14mm deep socket to remove it.
Might be a 13mm deep socket for removal? I vaguely remember needing a different size than for installation ...
