Interior sound mat under rear shelf
I had a water leak from the rear window seal. I removed the rear window. I took the rear shelf out. The sound pad looked fine but when I lifted it, the dryer lint padding attached to it was soaked on the passenger side.
The rubber pad weighs as much as a toddler. What can I expect if I just leave it off and put the rear shelf back on? No rust though. I know I have rust in the seat buckets, but that's another proj. Thanks for any insight.
78SC coupe, Silver Metallic |
i would imagine that it would be a little louder but i can't say if your ear will be able to tell the difference in a few dbs.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
I guess I can apply Dynamat later.
It will be quite a bit louder without the rear sound padding.
This I might like!
O.B.E.D.
I'm going to upgrade my firewall insulation and if you want to borrow my pad until you upgrade yours, you're welcome to use mine which is in great shape. I'm assuming that my "84" will fit your car. I can tell you the noise level will be significantly higher... I'll be in the DFW area on Nov. 13-14, PM if you want to get together...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Thanks Mitch.
I'll know if it is driving me crazy by then. Look forward to the meeting. I'll PM you. Ahh Fredericksburg. I love that town. So does my wife. I may be there after thanksgiving walking the streets. Best, Lee
AppBiz makes a nice light weight replacement for that heavy sound pad that was water soaked.
AppBiz.com |
Once a friend of Cliff
YES SIR!
![]() ![]() ![]() ![]() mr. miagi approves....
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
AppBiz has a GREAT lightweight replacement for that old heavy piece. Bob can help out.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
The Appbiz sound pad is the one that goes in the engine compartment. This post is about the sound padding in the interior that is under the rear parcel shelf, back seats, etc.
Appbiz makes a lightweight one to replace the interior engine sound pad too.
...along with carpet sets and RS door panels, etc.. |
i just put down a few extra layers to help with sound today. when the engine was out last week i noticed that all of the factory stuff inside the engine compartment was gone, most likely due to age.
skip to last post to see the parcel shelf. new audio install
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
They make both however the interior sound pad is not on their website. Call them up and you can order one. Mine arrived Friday. Very nice piece of kit.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
I don't think the engine side pad makes much difference. I haven't had one for years.
I do have the original interior pad, though. |
I used "rattle trap xxx" doubled. Easy and works great.
AutoBahned
people often say this when comparing their old, internally disintegrated pad with a bare bulkhead.
the real question is what a new one is like compared with nothing - the new ones weigh very little and are easy to install it is usually important to stop noise before it strikes a bulkhead - once that happens it can only be dissipated; if you catch it before it impinges on the bulkhead, then it will not be transmitted at all nother thing to do is ask if P AG puts these on the new cars - the 997, GT2 and GT3 |
