audiman08's Avatar
O2 Sensor ?
This may be a dumb question, but I'm relatively new to 911s. I decided to remove my heat exchangers on my '75 911 S and replace them since they were rusting. I also pulled out the cat, and plan on replacing it with a cat bypass (since historic vehicles as exempt from emissions testing here). Anyway, I was looking for the O2 sensor and couldn't find it....anywhere. I am wondering if the previous owner unplugged it and adjusted the mixture to run lean. It doesn't seem I've been running very rich, but I'm a little concerned what this did to my engine. Where does the wiring run so I can put an O2 sensor in, and will I need to readjust the mix if he's tinkered with it? Thanks
Old 11-21-2009, 12:41 PM
kodioneill's Avatar
1975 911's did not use an O2 sensor.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-21-2009, 12:53 PM
audiman08's Avatar
Oh, well that makes it easy! Thanks
Old 11-21-2009, 01:51 PM
