O2 Sensor ?
This may be a dumb question, but I'm relatively new to 911s. I decided to remove my heat exchangers on my '75 911 S and replace them since they were rusting. I also pulled out the cat, and plan on replacing it with a cat bypass (since historic vehicles as exempt from emissions testing here). Anyway, I was looking for the O2 sensor and couldn't find it....anywhere. I am wondering if the previous owner unplugged it and adjusted the mixture to run lean. It doesn't seem I've been running very rich, but I'm a little concerned what this did to my engine. Where does the wiring run so I can put an O2 sensor in, and will I need to readjust the mix if he's tinkered with it? Thanks
1975 911's did not use an O2 sensor.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Oh, well that makes it easy! Thanks
