nineball's Avatar
Originally Posted by Formerly Steve Wilkinson View Post
"for a few dollars more..."
Has nothing to do with the money, it's the inconvenience. Much more convenient to go to the Brita pitcher of filtered water in the icebox
by the same token it's much easier to drive down to autozone and get oil than it is to order some brad penn. to each his own.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-06-2009, 07:51 AM
moneymanager's Avatar
You guys have a lot of time on your hands. I asked a simple question, and look what happened...
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 11-06-2009, 08:02 AM
AutoBahned
RWebb's Avatar
Originally Posted by docrodg View Post
Let's see, College Physiology, Nursing School, Paramedic School, Lab School.
The problem is that distilled water is absolutely pure, so in the body it results in a very large osmotic pressure. This causes the intracellular electrolytes needed for cell function to migrate out. It also rapidly increases blood volume as the intestines are over-efficient in moving this pure water into the blood stream. That causes hypertension and can result in CHF (Congestive Heart Failure). This does not occur from one glass of water, but many, and only if it is not mixed with other things. Many drinks are made from distilled water, but there are minerals and ions put back into it that prevent the osmotic pressure rise as the water is no longer pure.
It appears you were misinformed.
If you ate nothing for some time, and drank only distilled water, then you'd most likely starve to death first.
I suspect an instructor was trying to make a point with hyperbole (so the students would remember it).
And, it we are talking about drinking massive amounts of water "poisoning" then any kind of water would kill you.
For batteries -- use distilled if available. If you know you have very low mineral tap water, there will not be much damage from using that. Sherwood pointed this out before.
Old 11-06-2009, 12:12 PM
