71 Porsche 911T 2.2 Battery Question
I am working on starting a 71 911 2.2 that has been in storage for years. My question is the car has two batteries is there anyway I can rewire and use one battery? if so a point in the right direction would be greatly appreciated.
Thanks, ________________ Bill 71 Porsche 911 T 2.2 05 Saab 9-3 Convertible Dufour Gib Sea 37 Sailboat |
Relatively simple.
Remove the passenger side battery. The heavy black cable now must be safely insulated from any ground (sheetmetal) which can be done by wrapping the end with rubber and securely taping the wrap to the cable, or use nylon ties to bend the cable back on itself--anyting to guarantee the end will not ever make contact with a ground. Or you can disconnect and remove the cable from the connector on the left side battery--that is the safest way. Remove the left side battery and buy a larger single battery that has enough power for the entire system. You will have to fabricate a hold down system outside the battery box as the larger battery will not fit. There are several threads in the Tech fourm which describes how others have secured the battery to a plastic cutting board which is bolted to the trunk floor. Technically, it's not difficult and many have done it--even putting the battery in the smuggler's box. Try a search, or maybe someone can post a link to a thread that runs through the conversion. Here are some links: Early Dual -> Single Battery Conversion converting to a single battery Dual Battery Questions - Help!! Share your LONGHOOD battery mounting solutions.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 11-05-2009 at 05:39 PM.. |
Thanks ossiblue, I will check the forums for manufacturing a new battery tray
On the left side you can remove the black wire on the positive battery terminal that runs behind the fuel tank. Than completely disconnects the right side.
In years past..we would get the battery for the VW bug that goes under the rear seat and use that for the left battery and the ground side would slide in the battery box. Bruce |
The battery tray the '74+ cars can use does not work for us dual battery guys. Of you go the Optima route, you can put the battery in sideways into the left hand battery box and make a strap. ![]() My story here: duel battries
Thanks for the link HarryD, I will set out this weekend to shop for a battery and then build the housing. I have some really good ideals thanks to you guys on Pelican.
Good question. Well for us with Dual Batteries the "standard" groups do not fit so you are limited in your selections. There is no reason not to have dual batteries if you so desire. For me, the cost of one larger battery was significantly less than two properly sized ones. From an earlier post of mine, the story boils down to: The cost of a lead acid battery is less until you consider the cost of a front suspension pan replacement from a boiled over or cracked battery. From another post (duel battries - Pelican Parts Technical BBS Quote:
