Pertronix-unfused (1863)
Installing a new "ignitor" in my 72. The directions show the red wire being hooked up to the +side of the coil. Seems to me.... It would be better or safer to go into one of the three fuses on the control panel and tie it to the fused side thus protecting the unit???? Not sure which one to hook it up to, but that is my theory???
Old 11-06-2009, 08:14 PM
My advice, don't second guess the manufacturer. The Petronix is designed for a direct current from the coil as are mechanical points, adding a fuse is asking for a weak link in the ignition "chain" to break--while driving, no less.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-07-2009, 08:35 AM
Send a message via Yahoo to tmctguer
for what its worth, here is a thread i started a few months ago about my Pertronix install in my '73 911e.
Pertronix Installation in '73 911E -- complete with photos
i don't know if it answers your question about "why", but my install came out swimmingly.
Rick G.
1973 911E (sold)
1989 911 Speedster (sold)
1993 Beck Spyder
2006 Ford GT (why I sold my Porsches)
Old 11-08-2009, 09:20 AM
UPDATE: PERTRONIX DOES NOT HOOK UP AS PER STANDARD PRINTED INSTRUCTION ON A PORSCHE WITH A CDI UNIT. DO NOT HOOK IT UP A SHOWN ON THEIR PRINTED INSTRUCTION SHEET. e.g. "connect the IGNITOR black wire to (-) side of the ignition coil, connect the red wire to the positive (+) side of ignition coil. THIS IS NOT GOING TO WORK. IN MY CASE, THE BLACK CONNECTED TO THE EXISTING EXTERNAL (1-BLACK,1-BLK/PURPLE) WIRES CONNECTED TO THE DISTRIBUTOR. THE RED I EXTENDED TO A IGNITION SWITCHED LEAD @ THE 3-FUSED CONTROL UNIT. OTHER THAN CALLING AND ASKING THEM, THE ONLY PLACE YOU CAN FIND FURTHER INSTRUCTION (A DIAGRAM) IS IN THEIR TROUBLESHOOTING SECTION.
NOTE: FUSE IS NOT CALLED FOR BY MANUFACTURE (SEE OSSI-B)
YOU CAN SLICE INTO THE CDI UNIT (SEE RICK'S....73 INSTALL--NICE WORK)
Old 11-10-2009, 04:03 PM
here is the correct picture from the Pertronix website for a CDI install.
Rick G.
1973 911E (sold)
1993 Beck Spyder
Old 11-10-2009, 07:11 PM
kwikt 911's Avatar
Agree... do not wire the Pertronix to the coil with a CDI.
Old 11-11-2009, 04:02 AM
