Capitalist and Patriot
911Freak's Avatar
Exclamation Rotate engine for valve adjust w/no access to lower nut? Ideas?
Hey Pelicans
I'm doing a valve adjustment on my 1980 3.0 (930/08)
Problem is I can't get access to the nut on the main pulley to rotate the engine because this 3.0l came with A/C and thus there is little to no clearance between the engine mount bracket and the double crank-case pulley to get the 26mm socket attached?!
Bentley, 101 projects and Haynes simply state to use a 26mm socket to access this nut and rotate engine, however they offer no recommendation for an alternative
I have been trying to use the upper pulley (alternator/fan) but with the resistance from compression the belt slips
I'm sure a pelican out there knows a solution
Thanks in advance
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 11-07-2009, 11:49 AM
Usually squeezing the belt together while turning alt. nut works. I think I used a work glove to avoid getting pinched. You could push on one side with an open end wrench too. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 11-07-2009, 12:00 PM
1980 911 SC
you use the nut on the alternator not the crankshaft, and pinch the belt like tigerrat explained
Life's a Beach
Old 11-07-2009, 12:07 PM
<insert witty title here>
Christien's Avatar
Yep, that's the way I always do it. Just swab some glue around the pulley to hold the belt.
Just hold the belt to the pulley with your finger - doesn't take much pressure to stop it from slipping.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 11-07-2009, 12:28 PM
Put the car in gear and push it.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 11-07-2009, 12:34 PM
911Freak's Avatar
Got it, Thanks guys!!
Formerly known as Syzygy
Canada Kev's Avatar
Is the belt tight enough? Mine is, but it still needs a bit of a pinch. When I did my first valve adjustment, the belt was way too loose, so I needed to move some shims around. This gave me the opportunity to take a closer look at my belt. It was cracked a bunch on the inside. Time to replace. Maybe it's telling you something?
Kevin
Old 11-07-2009, 01:41 PM
Connect remote starter switch to the starter solenoid and bump the engine into position. Make sure the ignition is OFF.
Sherwood
Old 11-07-2009, 02:14 PM
Pull the spark plugs first! Rob
Old 11-07-2009, 05:40 PM
docrodg's Avatar
Pull plugs, bump engine. Then should be able to turn belt to final position.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 11-07-2009, 05:51 PM
The "final position" doesn't have to be TDC. As long as the rocker arm for the cylinder is contacting the heel of the cam. That's the area the valve remains closed to adjust clearance.
While the engine can rotate easier with the plugs removed, leave them installed.
This reduces the chance of carbon flakes dropping off and temporarily lodging between valve and seat.
Sherwood
Old 11-07-2009, 11:00 PM
Burn the fire.
Brando's Avatar
For the fan pulley nut, use a shorty extension. To turn the engine over, pinch the belt then turn clockwise. DO NOT TURN COUNTER-CLOCKWISE!
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 11-08-2009, 12:42 AM
Rob's right. Pull the plugs. Way easier to do valve adjustment with the plugs out.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-08-2009, 05:36 AM
Somatic Negative Optimist
Gunter's Avatar
911Freak,
Along with valve clearance, I usually make sure that the rocker shafts haven't moved and check the torque on the head studs with a long 10mm Allen socket.
If you take the plugs out, you can check them for gap and condition.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-08-2009, 07:26 AM
pete3799's Avatar
I wouldn't pull the plugs before doing a valve adjustment.
If you do you risk dislodging carbon build-up that could get trapped under a valve and
affect your adjustment.
Chances are it won't happen, but why risk it.
Pete
79 911SC RoW
Old 11-08-2009, 07:27 AM
this is correct. the engine will turn over with the alternator nut easy enough if you push in firmly on the right side of the belt as you turn the pulley with the wrench.
206 637 4071
Old 11-08-2009, 08:21 AM
Gunter's Avatar
Cool
Yeah, never take the plugs out even if you need new ones after 50k Miles.
Every now and then, a thread appears like: Help, cannot get plug out.
Reason? Carbon build-up on the plug end. It'll move for a couple turns and then seize. It'll take some force to get it out. The danger here is that damaging the threads is quite possible because the plug is steel and the heads are ALU alloy.
If the plugs are left in for too long undisturbed, it might cause problems.
What to do?
IMHO, Nothing wrong with taking them out now and then to check condition, gap and carbon build-up.
Old 11-08-2009, 08:36 AM
bcgreen's Avatar
Gunter, I bet you don't see many P cars in your town?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-04-2014, 04:10 PM
TheSt|G's Avatar
5 years later, he might not even have it anymore...
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 11-04-2014, 04:33 PM
NEVER remove the spark plugs before you adjust the exhaust valves! There's a good chance you'll dislodge bits of carbon, and a very good chance (Murphy's Law) some of those bits will end up on a valve and/or seat, throwing off the adjustment. I recommend a remote starter button and watching for individual valves to fully open, adjusting the opposite valve each time that happens. As for the intervals, I would never run a spark plug in a 911 for more than 15K miles, especially in a turbo.
The Cap'n
Old 11-04-2014, 04:34 PM
