fireant911's Avatar
81 SC Oxygen Sensor Relay
I have a question regarding the Oxygen Sensor Relay (under the passenger's seat) on my 81 SC. What are the indications that the relay is not working? My SC started suddenly misbehaving recently. On the morning in question, it fired up fine and all was normal. Halfway through my trip to work I noticed some slight hesitation when accelerating. Along with this hesitation, I discovered that my A/F meter was reading nothing… Now when I crank it up, it starts and idles fine but burps and spits when the accelerator is slightly depressed.
Years ago, I tried replacing this relay with a regular one at an automotive shop and discovered first-hand that all relays are not created equal. I promptly reinstalled the original relay. As my memory serves me, my car behaved almost the same back then with the wrong relay as it is now with the right (but old) relay. Is this a sign that my real Bosch relay is no lower operating properly?
Any help will be appreciated as I do not want to start randomly buying parts without knowing if this is a possible culprit.
Daryl G.
1981 911 SC - sold 06/29/12
Old 11-07-2009, 02:27 PM
I found that replacing the relay with something from the store made me question the quality. I had an 83 that I thought the warm up regulator was going bad, after replacing it still was bad, a friend showed me the error of my ways and replaced the relay from the store, worked long enough to make me think it was working aqnd went south again. The original relay is VW marked, went to VW and they couldnt find it so I ordered new from dealer.
Relatively inexpensive, problem solved
If you still have problems, start at the fuse board checking the system.
Bruce
Old 11-07-2009, 02:55 PM
Daryl,
Do yourself a favor and learn how to hook up a dwell meter to the lambda test port. The Bosch CIS lambda will talk to you, all you have to do is listen. It will tell you immediately if the system is working , and give you a proxy for the mixture, allowing you to make intelligent adjustments. All you need to know is available by searching this site.
Paul
Old 11-07-2009, 03:24 PM
I have had the relay go bad and car was under no way able to drive , it would start rough but you could not drive. I found the relay was bad and went to my local Napa for a replacement. The Napa relay worked like a champ and I did not think much of it till trying to diagnose a small cold start issue. I have all components of my CIS working and within spec. I was chasing a small problem to make perfect and I thought maybe the Napa relay could be the issue. I ordered the stock relay and found it was 100% the same as the Napa as far as every CIS test that could be run.
82 911SC
74 MGB
97 Land Rover Discovery
Old 11-07-2009, 03:41 PM
just unplug the relay and see if the idle gets all wierd. if nothing changes, then it's not working. it gets power from the domelight fuse, so if the domelights work, no need to check the fuse. you can also pull the fuse to check.
206 637 4071
Old 11-07-2009, 04:13 PM
fireant911's Avatar
A quick follow up question... I ordered a new Oxygen Sensor Relay from our host and installed it this morning. Replacing this component certainly corrected the issue but oddly the car seemed to run much better than before the misbehaving started. I was under the impression that the relay's operation consists of either on or off (continuity or no continuity). Is it possible for a relay's performance to degrade while still operating properly?
It is possible that not having driven the car for three weeks could have made it seem more responsive, quicker revving, and stronger. However, the car was truly a much more enhanced tiger and the change was too dramatic for me to actually believe that this 'forgetting' theory is accurate.
Daryl G.
Old 11-14-2009, 11:20 AM
No, I think it is your imagination. Now that you think you have fixed the problem, my advice would be to actually test the system and see if it is functioning correctly. Fifteen minutes with a dwell meter will give better results than speculative theories.
Paul
Old 11-14-2009, 01:32 PM
Peter Zimmermann's Avatar
I have experienced first-hand, on more than one occasion, what you experienced. Relay replacement can feel like you've given a car 30 hp + a smooth pill. When the relay fails the car will cold-start poorly, and run badly through its warm up cycle. When the car reaches full temp it can "feel" almost normal, but after a cool down the same running issues occur. Glad it's fixed!
Keep the Shiny Side UP!
Pete Z.
Old 11-14-2009, 03:09 PM
mca mca is offline
mca's Avatar
Just wanted to add to this discussion for others in the future.
Yesterday I had a strange cold start issue. It was running really lean, rough and the idle was low. Not driveable.
I pulled my air filter and lifted up on the sensor plate. Strangely the car recovered and immediately acted normal. I just figured that my sensor plate was getting sticky and wasn't able to lift enough to richen the mixture during the cold start.
So I drive off and everything is perfectly normal. About 20 minutes later (in a SHADY part of town) my idle dropped like a rock at a stoplight. I limped off of the road and into a parking lot. The car was again running VERY lean. Spitting, popping and not driveable.
After talking to a local Pelican on the phone I swapped my 02 sensor relay (always carry a spare). Car ran perfectly after that. I drove it at least 60 miles today and it was flawless - including the cold start.
Now for my question ... how do I remove the orginal relay from under the seat? I am not familiar with how it is attached to the bracket - don't see any way to remove it. Tips anyone?
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 02-28-2010, 05:16 PM
KNS KNS is offline
mca,
Just pull it off like any other relay, it may be stiff so give it tug.
Kurt
Old 02-28-2010, 05:42 PM
mca mca is offline
mca's Avatar
It is mounted to a bracket. Can't just pull it off.
Old 02-28-2010, 05:57 PM
grateful user
don gilbert's Avatar
the one attached to the bracket is a enrichment module for very cold days,(82-83 only. the 02 relay is usually just loose next to the ecm
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 02-28-2010, 06:32 PM
mca mca is offline
mca's Avatar
The relay on the bracket is the one I replaced. Had same part number as the o2 sensor relay : 821-951-253.
I don't have any other relay under the seat.
Old 02-28-2010, 06:56 PM
grateful user
its not really a relay, but kind of looks like one. its an 82-83 only fuel enrichment gizmo that works of the secondary temp switch by the oil press switch/breather area. it is attached directly to the ecm, or is supposed to be.
Old 02-28-2010, 07:56 PM
mca mca is offline
mca's Avatar
After further investigation I discovered that the original relay has a clip on it. It slips over a bracket next to the ECU. Initially I thought that it was permanently attached to the bracket.
I also firmly believe that these relays don't always fail suddenly. In my case, the relay failed over a period of weeks (and possibly months). How can this be? Intermittent connection failure?
I am also convinced that my car gained some serious boost with the new relay. Call me crazy but I rebuilt this engine 9k miles ago and I know it well. I have never felt it pull so hard through the entire rpm range. It was actually kind of scary today.
Old 03-07-2010, 02:30 PM
poor contacts = voltage loss. end result is the freq valve works, but poorly.
206 637 4071
Old 03-07-2010, 05:05 PM
Hi, resuming this old thread cause I have the same issues of popping and spitting on my SC, plus, I noticed I have some malfunctioning on my dome light, thus hope I got to the point. I just don't understand where this relay is to be found. Can you guys help? Will take the dome light apart and clean the contacts in the meantime...
Thanks!
Old 04-01-2012, 04:13 PM
SC with lambda........
Marco,
What year is your SC? This relay (OXS) is for late SC's with lambda. The early SC's ('78-'79) don't have this relay and no OXS. Keep us posted.
Tony
Old 04-01-2012, 06:31 PM
Mine is 1982, and I have the lambda system. I'm checking underneath the right seat and see if I find this one relay. As far as I understood, all I can do in order to test it is unplug it when the engine is idleing and see if runs badly.
John Walker once said "hook the jumper to power with key on only, if you have to drive it until you get a decent relay". Can you maybe explain what this means, just in case I (hopefully!) find out the relay is the problem? I just bought my SC last week and I really look damn forward to have it run smoothly ;-) I guess I'll check the O2 sensor too: is it correct to get a volmeter and attach the red cable to the sensor's wire and the black cable to ground and see if the voltage fluctuates between ~0.2 and 0.8 V?
BTW, I saw the famous dome light smoking the other day, thus I assume there's really something not working around there, let me go and check...
Thanks a lot!
Old 04-02-2012, 01:12 AM
O my Gosh, the stupid relay... just touched #30 with #87 and #87b and the freq. valve started buzzing. Idleing jumped higher in revs and engine runs amazingly, something I didn't have the chance to know in my first P week :-)
Will be connecting the wires to power with key on only till I get a new relay.
Thanks to everybody!
1982 911 SC Targa (USA)
Old 04-02-2012, 04:53 AM
