twin cam motor in a vw bug
I was fortunate enough to go through Barron Colliers museum over the weekend and he has a 64 beetle with a twin cam 4 cyl. motor stuffed in the back. It was really cool. He has a great assortment of Porsche race cars and some very nice road cars as well. 110 cars total (not all Porsches) . Millions of $. Great Museum but no longer open to the public, unfortunately.
1988 cab. Gone but not forgotten 2002 BMW 540i 6SP SOLD 2003 BMW M5 1978 MB 280 CE PROJECT (PAIN) 2004 HONDA ACCORD DD |
gearhead
Ttwwp.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Ttwwp. ?
muck-raker
Ttwwp...should be, Ttuwp.
Ttuwp = This Thread is Useless Without Pictures. now, if somebody can tell me what VMMV means.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I believe it is YMMV Your Mileage May Vary
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
denny aker has one too. he runs a shop here in seattle. pardon the somewhat blurry pic.
gearhead
the one I saw had a flat fan, not vertical.
3 restos WIP = psycho
day-ummm!!!
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
just me
ok, so what does FTW mean?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
I really screwed up and went with out a camera. With a flat fan I assume it was a carrera gt motor.
Wow, I've heard that those motors can be worth up to 6 figures......
We have rebuilt a few of these things.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
thanks Steve for the insight. Just what motor was the one I saw? Flat fan, and what I would call a distributor that looks like yours, but on left side of engine. Similar to the more common position of say an 87-89 carrera. Thanks Paul
Adrenaline Junkie
Adrenaline Junkie
Now,, how about a Bug with a flat six in it? Anyone?
Diss Member
The combination of a 911 motor in a Bug was sorted out by a guy named Whitey Davis in the 80s. Whitey's 911 powered Super Beetle would carry both front tires out of the corner when ice racing in a "super stud" class (3/8" studs) and would leave a rooster tail of ice chips quite a bit higher then a light pole. It was jaw dropping and pretty impossible to see anything if you were behind him.
It is currently a winning combo in the Alaska Sports Car Club. Currently Chad Yosh-itomi and Jim Hemmesch are running the same basic package. If I remember correctly Whitey said that his car was about 1300 pounds. (BTW Wayne: Need to lighten up a touch on the "dirty word" filter so it doesn't block a common Japanese name. Yosh-itomi=Yo****omi?) Here are a couple pics of Jim's car: ![]() ![]() Here are a few videos. (Chad's car is red and Jim's is blue): And here are a couple in car videos. Chad is a pretty amazing driver so his video is a bit boring because he is out front. As you can see slideways driving skills are important when the changing sun allows different parts of the track to freeze during a race. The used to put 1500lbs of salt down on the road each day to keep it melted. (Salt-cicles in a race car sucks! A roll cage shouldn't rust away in 3 years...) They switched to using urea in the 80s and I assume they still do for environmental reasons.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Flat fan in a bug - could it have been a:
Corvair? ![]() VW Pancake?
David 1972 911T/S MFI Survivor |
VW beetle Carrera engine
Hi All, \has anyone noticed the double ignition that the engine has.....Spyder or 904 engine ??
just my 2 pfennig's stefan
with regards Stefan |
Adrenaline Junkie
It would be insane if someone was running one of these with a street set up. Sorry for the hijack. |
