85 Targa
O2 help
I had to replace my catalytic converter and the oxygen sensor. The old O2 had seized up in the old Cat.The old O2 had just one black wire to it. I ordered a new Bosch OME Oxygen Sensor and it came with 3 wires (one single black plug….ground I guess) and (one two prong plug white and black). I found where the single (ground wire?) went the ground headed to the DME ground. I would assume that the other two prong plug should go somewhere in the eng compartment. I have look hard for a plug with one green wire and one yellow wire (going by my electrical wiring diagram). I can't even find any wires not being used. Any ideas on were the wire come from that goes to it. Like is it near the eng compartment fuse box???
Thanks Brian 1985 Porsche 911 Carrera |
grateful user
That is a heated 02, go to O"reily and get a bosch 1 wire for 20 bucks. it will work fine. it will last longer to.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. Last edited by don gilbert; 11-14-2009 at 04:24 PM.. |
O2 Sensor connector
This thread shows an 85 with the connectors in the engine bay. The connectors are known to break. Perhaps removed by previous owner? 2 wires are for the heater, green should go to DME. |
85 Targa
I forgot to mention that my car is a Euro. Maybe that why I cant find the yellow and green plug wire.
