Mike the mechanic
Guest
Posts: n/a
Nice car ks911! You get Porsche styling, handling and prestige with an awesome v8 rumble.Imagine you would supercharge it! Wheelies! Sure the F6 sounds great but so does the V8. I wonder if certain people would get worked up if you had installed a 928 engine...
Bottom line is, you have a fast, good-looking CAR that you built yourself (how many people can say that?) and are having fun with.
Mike
86 Carrera t (notice the t anyone?)
Old 02-05-2001, 07:09 PM
Kurt B
Guest
Posts: n/a
Good luck with it. At least it's not the same monstrosity posted a ways back where some old guy from Mississippi or somet place, put a chevy engine in the Front trunk of a 70s 911. Then he added all this stupid body crap that was square or something. It had this blower coming out of the front trunk.
You know, I still can't get the picture out of my head. It's like that Mpeg that floated around a while back where some monkey stuck his right hand up his ass and smelled it, then fell off the tree. Like that Mpeg, I can't erase from my mind, the image of that f'ing blower coming out of the front trunk of that 911.
After that old guy did that, I wonder if he too, stuck a wrench up his ass and smelled it.
Kurt B
1984 911 Carrera Cabriolet
75 914 1.8
[This message has been edited by Kurt B (edited 02-05-2001).]
Old 02-05-2001, 07:33 PM
ks911
Guest
Posts: n/a
Hello everybody,
I was a little supprised to see this post still active, and I see the judgemental people are still out in force. Bottom line, it is my car and I love it,,,get over it!!!!!!!!!!!!!!!
To the unjudgemental people here is an update. I have tracked the car at Carolina Motorsports Park and was very pleased. The car really didn't handle any differantly than it did before the swap, I had changed to 26mm rear torson bars so that kept everything neutral. The weight bias is 63/37 which is the same at a 930 I think or real close to it. The brake upgrade works well and at a cost of around 1000.00. As far as drivability the car, it is quieter than a F6 at highway speeds, remember there is no fan spinning. And the torque makes it very easy to drive in traffic because there is plenty of torque to pull from 1,000rpm.
This car started out as an abused 76' 911S with a blown motor and a worn out trans. And if I choose to go Porsche power tomarrow I just remove everything, change the gas tank and replace the piece of metal that I removed and saved from the front of the trunk, since this acts to let air get to radiator. Then in goes the F6, I didn't even cut the wiring harness.
As for the cost I think I have around 7,000.00 in the conversion which includes 1,700.00 worth of gears and a overhaul for the trans. Clutch was kind of steep at around 700.00 for the kevlar disc and stronger pressure plate, turns out no stock Porsche 225mm clutch can handle 435 ft\lb of torque. The good news is that even if I blow a hole the size of VW in the side of the block the cost of repair is a joke compared the last Porsche engine I smoked.
I hope you all find this enteresting, and if you wish to post some more neg. stuff I really don't care I stopped being influinst by other poeple many, many years ago.
Old 02-05-2001, 07:58 PM
pbs911
Guest
Posts: n/a
Just what I meant. I would probably do the same.
Old 02-05-2001, 08:09 PM
JackOlsen
Guest
Posts: n/a
Suspending judgment on historical or aesthetic grounds, I'd like to see a sheet of stats on the thing, like:
0-60 times
0-100 times
quarter mile times
top speed
honest horsepower at the crank and at wheels
overall weight
accurate front-rear weight ratio (from corner balancing scales)
lateral g capability
I'll loan out my g-tech pro, in the interests of science (or, for the critics, here: in the interest of studying something in the same fashion the NTSB studies crash sites).
This is clearly not what a lot of 911 owners want to see happen to the rapidly-diminishing pool of the world's air-cooled Porsches. But then again, 911s get junked all the time, and the 74-77 American cars get junked more than most. You clearly are taking care of this car, although not in the fashion that makes this board feel most comfortable.
It's a nice looking paint job.
Do you do anything to the oil pan to correct for G forces?
Jack Olsen
1973 911 T (3.6) sunroof coupe
jackolsen@mediaone.net
[This message has been edited by JackOlsen (edited 02-05-2001).]
Old 02-05-2001, 08:13 PM
ras911
Guest
Posts: n/a
Excellence was expected???????????
[This message has been edited by ras911 (edited 02-05-2001).]
Old 02-05-2001, 08:33 PM
VIPRKLR
Guest
Posts: n/a
Yes RAS - that is why Porsche left room for a V8
Old 02-05-2001, 09:28 PM
old_skul
Guest
Posts: n/a
It's......
THE THREAD THAT WOULD NOT DIE
Gawd, check the post dates on this bad mother!
Mark Szabo
1986 911 Targa 3.2
1987 Escort 5-speed 1.9
The Porsche Owners Gallery
930fan
Guest
Posts: n/a
ks911,
As a general rule, I believe that if you haven't got anything good to say then it's better not to say anything. However, since you've said you don't care what the anti-Chev brigade has to say then it leaves me free to say this - you are a butcher.
Why the hell do you have a Porsche in the first place if you like pushrod v-8s? It's akin to having a Supermodel with a 1st class from Oxford in Latin for a girlfriend and then slapping on a set of Pamela Anderson boobs and transplanting hooker's brain in so that it's easier and cheaper for you to get your kicks in the sack with her.
Pushrod v-8s go with leaf springs and live axles as it suits the primitive power delivery characteristics ( wow at 2000rpm and breathless at 5000rpm). Why put an ancient, top heavy v-8 in the back of an air-cooled flat 6? For the nearly 6k you spent excluding the trans. mods, you could have sold your 2.7 and added the proceeds and a bit more towards a 3.6 swap and got a well respected, near 300hp true Porsche instead of a car that will get you sniggers, incredulity, bewilderment, disgust and nausea from the Porsche and Chevy groups.
"Its only worth doing if it's done properly". These are words worth remembering. If not I'll just go out and get a Fiero based F40 replica, put a built pushrod v-8 in it and say look, I've got more torque at 2500rpm than those know nothing Ferrari engineers and it only cost me 5% of the real thing. If your budget limits your Porsche power options, live with it like 99.99% of P owners do. Please don't butcher your car (no matter how "neatly") and expect kudos and a pat on the back from those that appreciate that 911s'have flat 6 engines.
Old 02-05-2001, 10:28 PM
Blackfoot
Guest
Posts: n/a
i find it amusing and a little sad that some people would use the word "butcher" when describing an automotive modification. glad to see were all keeping level heads.
personally i wouldn't do a v8 mod in a 911 (but WOULD in a 914, 924, 944 or 928) because of the already strong rear weight bias. i can speak firsthand of the tricky and frankly negative handling aspects of the 911 as i drove mine at sears point this past sunday. i can imagine it would only be stronger in a 930 or 911 v8 conversion.
a 911 isn't going to out-handle most performance cars anyways, but you'll be smoking virtually any car in straight line acceleration.
Old 02-05-2001, 11:03 PM
diverdan
Guest
Posts: n/a
Back in the late sixties a buddy of min e had an aluminum bodied Ferrari 250 shortwheelbase that Bob Grossman had campaigned. We loved driving that machine, but when the Pontiac GTO s wanted to drag, he would say, "Road course, top end or disconnect 3 or 4 of those plug wires so we both are running on 180 cubic inches." At that time the value of his car was roughly equivelent to the price of a new muscle car.
Old 02-06-2001, 01:32 AM
Russla
Guest
Posts: n/a
I'm amazed at the Porsche nazis here. So what if he modifies his car? so what if it's not a true Porsche? Get a grip on what's important. So what if the motivation is economic. Yeah he's too poor to do it the right way, if he had the money he'd do a 3.6 TT. As if not having gobs money to burn is some character flaw. Perhaps telling others how much you're going to spend is more demonstrative of a character deficiency
Some people may still enjoy driving fast, but not have lots of money, or concern about factory purity. A V8 seems a quick and easy way to go towards providing the enjoyment that he's after, which is driving a P car with lots of torque, that doesn't burn much oil, and adjusts it's own valves.
Old 02-06-2001, 02:51 AM
Obin Robinson
Guest
Posts: n/a
a Porsche with a Chevy engine is technically a "Porsche-Chevy".
a Cooper body with a Porsche engine is technically a "Pooper"
i dunno, i'd rather be in a Porsche-Chevy than a pooper. you now join the ranks of Spice Chevy, Rondeau Porsche, Fabcar Porsche, Lola Porsche, and Kremer Porsche. as everyone knows, those are all VERY potent cars.
obin
Old 02-06-2001, 05:29 AM
Hatari
Guest
Posts: n/a
Now I feel liberated. I used to worry about other's reactions because I used a wing instead of a ducktail on my RS lookalike...
May the festivities continue!
Old 02-06-2001, 05:42 AM
RarlyL8
Guest
Posts: n/a
I must be the Porsche butcher from Hell. I took a no rust, bone stock, low mile, one owner SC and did the flair fandango. Changed the most disgusting color scheme I've ever seen into a real eye popper.
Now I've got a fresh 930 for it and am quite seriously considering selling it. Obviously the money issue is passed tense. The motor is mine. But the cost of upkeep and upgrades is beyond resonable. The 911 is only a car. It is an extremely cool car, but that's it. I may already have the worlds most expensive SC. Adding a 3.3T will only up the money pit total $15K by the time 400HP is realised. I must admit thought that I cannot bring myself to put a small block in it. The sound of the 6 and the look of the engine help define the car. When you can't decide what to do, do nothing. So the 3.3T will be asembled and sit until I make up my mind. My old street machine sits right next to the 911 in the garage. $10K worth of blown aluminum big block would go a long way in the scare-the-****-out-of-you department. Hmmmmmmmmmm
Old 02-06-2001, 11:01 AM
Lindy
Guest
Posts: n/a
As a new member of this BBS, I was disappointed at the (few) negative responses.
We have been around vintage racing in the U.S. and Europe for years, and the one lesson that I have learned from people who have guest-driven my cars is that everyone has his or her own idea of what constitutes a "correct" vehicle. Some of most well known drivers and collectors are also some of the people least prone to criticize others, as long as someone does not intentionally misrepresent a vehicle. Granted, the owner of a bogus car who gets caught lying is going to get nailed...sometimes hard. However, I would rather have one more person active in the motorsports hobby with an honest, if incorrect vehicle than loose that person's involvement to some other activity. After all, this is supposed to be about having fun.
Old 02-06-2001, 12:16 PM
Pillow
Guest
Posts: n/a
We need three pages to this thread so I will throw my opinion in.
Would I add a V-8 to my SC? No. No way. I enjoy the air-cooled motor and like to work on it because it is basic and can live a long life. I also like screamer motors which the pushrod V-8 will not do.
Do I like American iron? Yes, I use a '71 Chevy C-10 as my daily driver with an ancient three-on-the-tree. It is very reliable and easy to work on. Plus I need it for my business, so practical also.
Do I drive a bastardized SC? Yes, I ripped the A/C out, have a Nardi steering wheel, K&N air filter, aftermarket stereo, Mobil 1 and Swepco 201. I plan to bastardize it more with fiberglass front and rear bumpers, tower brace, supertrapp exhaust, and sport seats w/ harness. Yes, it might drop resale value, but I do not plan on getting rid of it.
I like air-cooled cars that handle well. This means I must drive a Porsche 911. If I had to buy a 2001 sports car I would have to go with a Corvette or Boxster. Porsche with water is not my thing, it is just a car. The air-coolers are magic.
If Porsche makes that SUV I may rip all the "Porsche" logos off my car also!!! GD sacriledge!! I cannot believe BMW sold out to this fad of ill-handling, gas-guzzling, no-braking, and soccer mom driving SUV crap. Be practical and get a minivan because you know that SUV will never see off road conditions.
My only flame is that ks911 used a steal block instead of a custom aluminum mouse block. That may take the weigh issue out of it? Granted the CG will still be higher.
ks911 - Do you want to get rid of the blown 2.7L cheap? If so shoot me an e-mail!
Peas,
Adrian Pillow
1979 911 SC
1966 VW Microbus
PCA - Peachstate Region
Old 02-06-2001, 01:54 PM
magilla
Guest
Posts: n/a
I dunno... I like he Porsche 911 as is. almost any style. There are some I like better than others, but I like them all. There are also things that I want to do to my '83SC to make it non-stock. I added H-4's, I want 17" rims, I want an upgraded oil cooler, upgraded brakes, and maybe new seats. Most of these would be "permissible" by the majority of you, but it sure as hell wouldn't be a stock SC.
I would rather see someone take an otherwise abused or neglected body and put some time and care into it, than trash it or beat it into the ground. What ever you do with your car is your choice. I may not like it, but you don't care what I think, and when it comes down to it, I don't give a sh** what you think. I am always happy to share information as are most people. Give your opinions, be funny about it, and we all learn and enjoy.
Summary: I don't like what you did, but I support your right to do it. I'm glad you weren't just a maniac butcher, and you spent plenty of time and money on it. Congrats, and I hope you enjoy your success!
Magilla
Old 02-06-2001, 03:52 PM
lucky77
Guest
Posts: n/a
Until Dr. Porsche flips the bill for my poor 2.7 problems I'll agree with any conversion.
77 911S
Old 02-07-2001, 12:26 AM
stormcrow
Guest
Posts: n/a
From what I can tell, one of the main reasons for converting a Porsche is the cost of maintaining the existing equipment.
Porsches are complicated machines. Set a Porsche engine alongside a 350 and you definitely see a difference.
That being said, I think there is a lot of fustration in owning a Porsche because of this. Not every nut driving, wrench toting mechanic can work on it let alone diagnosis its symptons. So what does that say about us as owners.
If we have the capabilities of keeping that machine in top running condition, and can diagnos and make repairs, that defnintely has something to say about our capabilities.
Look at the wiring diagrams, or follow the fuel flow. You just can't take the car to a garage down the street and say fix it.
Although I disagree with people wanting to make changes to their P machines, and I can understand why. Don't take this the wrong way, but fustration makes us do things we normally would't do especially when it comes to solving P problems.
Old 02-07-2001, 03:41 AM
