-   -   engine drop help needed - final steps (http://forums.pelicanparts.com/porsche-911-technical-forum/512113-engine-drop-help-needed-final-steps.html)
sfoster13 11-20-2009 02:28 PM
Originally Posted by 304065 (Post 5022994)
Thanks, that helps. So I've got the wrong transmission???
304065 11-20-2009 03:07 PM
I don't understand what you mean. All 2,2 liter cars (1970 and 1971) came with the 911 transmission, that is the "right" transmission for your 1971T. It is a great transmission, I have the same box in my race car. It's just that the clutch actuation is funky.
sfoster13 11-20-2009 03:24 PM
yeah, i got confused by one of the posts...understand now
vulcan300 11-20-2009 08:06 PM
Are you having trouble removing the CV from the motor end or the wheel end? I endured a painful few hours of CV removal on a 1970s 914 in the summer time. The paper gaskets had fused the CV to the brake disc assembly and no amount of banging in the world would get hem apart. In the end I took off the brake disc which allowed me to get the whole CV out. I'm not sure if the setup is the same on your car but this might give you a lead.
J
Joe Bob 11-20-2009 08:24 PM
If you can get the CV off at the trans, you can take the nut off the axle at the disc and pound out the whole assembly....
sfoster13 11-21-2009 06:43 AM
I'm trying to get the CV off the transmission end to drop the engine
Joe Bob 11-21-2009 07:55 AM
Heat and a hammer....are they off at the wheels? If not, try and get them off and then bend the axle at an angle...
sfoster13 11-21-2009 08:17 AM
Not off at the wheels - where exactly do they separate? Is it at the plate/flange that the bolts screw into where there appears to be a gasket?
Joe Bob 11-21-2009 08:20 AM
yes....they should have the same sized fasteners unless it's an updated one piece version.
sfoster13 11-22-2009 07:44 AM
Got them off
thanks for the help - for those trying the same thing here is what you need to do:
There is a gasket shown here in white that has to be removed. It's like glue. I did as recommended and just used a chisel directly on the white gasket area. Don't be shy, hit it good.
http://forums.pelicanparts.com/uploa...1258904446.jpg
then, take a big screw driver and wedge it in the gap from the gasket and pry the roll pins out. work your way from one side to the other
http://forums.pelicanparts.com/uploa...1258904497.jpg
http://forums.pelicanparts.com/uploa...1258904609.jpg
sfoster13 11-22-2009 01:16 PM
Success! Thanks for the help.
http://forums.pelicanparts.com/uploa...1258924507.jpg
http://forums.pelicanparts.com/uploa...1258924531.jpg
Joe Bob 11-22-2009 01:56 PM
Good for you.....A BFH is a good tool....
sfoster13 11-22-2009 04:11 PM
For those interested - I got the clutch cable off by hammering out the clip that was set in the case. You drive it towards the back of the car.
