Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
engine drop help needed - final steps
Car is a 1971T
Can't figure out how to remove the clutch cable and get the CV joint separated.
What do I need to loosen in order to separate the clutch cable? I've got the adjustment nuts fully loosened.
Have the 4 bolts out of the CV joint but it won't separate.
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 11-20-2009, 10:12 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
kodioneill's Avatar
You can hit the cv joints with a dead blow hammer, work around the joint hitting it outwards.
Don't understand your other question. separate the cable from what?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-20-2009, 10:17 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
the clutch cable is attached to the fork on the transmission - doesn't it need to come out?
Sean
NASA GTS2
Old 11-20-2009, 10:32 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
This is a bad picture, but this is what I'm talking about
Sean
NASA GTS2
Old 11-20-2009, 10:36 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
does the clutch pin separate from the throw out lever?
Sean
NASA GTS2
Old 11-20-2009, 10:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
kodioneill's Avatar
sorry how about a better picture. Pry the TOB lever towards the back of the car and you should be able to get the clevis out of the fork.
1982 chiffon 911sc
Old 11-20-2009, 10:54 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Sean
NASA GTS2
Old 11-20-2009, 11:08 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
kodioneill's Avatar
OK, do what I stated in the last post.
1982 chiffon 911sc
Old 11-20-2009, 11:25 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
I don't think that's right because the cable is still threaded through the case. I'm thinking it has to disconnect some place else.
Sean
NASA GTS2
Old 11-20-2009, 11:28 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
kodioneill's Avatar
Looking closer it seems the clutch cable is separated can you widen the angle of the shots and try to include more of the area in the photos?
1982 chiffon 911sc
Old 11-20-2009, 11:32 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
kodioneill's Avatar
This is what it should look like
1982 chiffon 911sc
Old 11-20-2009, 11:47 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
304065's Avatar
On a 911 box the clutch cable end is fixed to the transmission and the HOUSING actuates the clutch. Weird but true.
On the CVs, once the bolts are out there are two steel roll pins holding the joint to the stub axle.
Be careful under the car! Good luck!
Note-- the above picture depicts 901 transmission, not a 911. This is what a 911 looks like.
John C.
'66 911 #304065
'71 911E PCA H-Stock Club Racer #806
Ex-'88 Carrera (Sold 3/29/02)
Old 11-20-2009, 11:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
For a '70 or '71, it isn't the clutch cable that does the work, but rather the clutch cable sleeve which flexes when the pedal is depressed/released.
The cable end is hard attached at the rear of the transmission (left side of the picture). You do have to loosen the adjustment nuts on the throw-out arm to the point where you can remove the clevis and then the cable end from it's hard mount on the transmission.
Clean up the whole area so you can see what is going on.
Old 11-20-2009, 11:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
kodioneill's Avatar
He has the clevis type 1972 on
1982 chiffon 911sc
Old 11-20-2009, 11:53 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
I loosened the adjustment nuts all the way and still couldn't remove it. Not sure I see how to get the cable through the attachment point in the case either.
This is a 71 901 transmission. I guess it could be a 72 clevis type given that 71 was a wacky transition year.
Sean
NASA GTS2
Old 11-20-2009, 12:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
kodioneill's Avatar
It looks like the hole (that the cable passes through) is rusted up.
1982 chiffon 911sc
Old 11-20-2009, 01:01 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
304065's Avatar
Look, you can see that this is a 911 box, not a 901 or a 915, from your photos. The cable passes through a hole in that tab.
John C.
'66 911 #304065
Old 11-20-2009, 01:17 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
304065's Avatar
Better pics of the attachment point here:
A little help with a 1971 911/01 transmission
John C.
'66 911 #304065
Old 11-20-2009, 01:20 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
There aren't any nuts on the far side of the tab, just what looks like a cap on the cable. I'll take a picture. I think I might need to cut it.
Where on the CV are the roll pins?
Sean
NASA GTS2
Old 11-20-2009, 01:23 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
304065's Avatar
See this thread. It should slide out sideways once tension is off.
clutch cable for 70-71 901
The pins are between the mating surface of the output flange and the body of the CV. If you have the bolts out, you should be able to push the CV toward the other CV slightly and it will come loose. There are paper gaskets on there, you probably can't see them due to grease, but they are there. Our host has replacements.
John C.
'66 911 #304065
Old 11-20-2009, 01:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
