Originally Posted by 304065 View Post
Better pics of the attachment point here:
A little help with a 1971 911/01 transmission
Thanks, that helps. So I've got the wrong transmission???
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 11-20-2009, 02:28 PM
304065's Avatar
I don't understand what you mean. All 2,2 liter cars (1970 and 1971) came with the 911 transmission, that is the "right" transmission for your 1971T. It is a great transmission, I have the same box in my race car. It's just that the clutch actuation is funky.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-20-2009, 03:07 PM
yeah, i got confused by one of the posts...understand now
Sean
NASA GTS2
Old 11-20-2009, 03:24 PM
Weekend Mechanic
vulcan300's Avatar
Are you having trouble removing the CV from the motor end or the wheel end? I endured a painful few hours of CV removal on a 1970s 914 in the summer time. The paper gaskets had fused the CV to the brake disc assembly and no amount of banging in the world would get hem apart. In the end I took off the brake disc which allowed me to get the whole CV out. I'm not sure if the setup is the same on your car but this might give you a lead.
J
86 911 Carrera Targa
Old 11-20-2009, 08:06 PM
RETIRED
Joe Bob's Avatar
If you can get the CV off at the trans, you can take the nut off the axle at the disc and pound out the whole assembly....
Old 11-20-2009, 08:24 PM
I'm trying to get the CV off the transmission end to drop the engine
Sean
NASA GTS2
Old 11-21-2009, 06:43 AM
RETIRED
Joe Bob's Avatar
Heat and a hammer....are they off at the wheels? If not, try and get them off and then bend the axle at an angle...
Old 11-21-2009, 07:55 AM
Not off at the wheels - where exactly do they separate? Is it at the plate/flange that the bolts screw into where there appears to be a gasket?
Sean
NASA GTS2
Old 11-21-2009, 08:17 AM
RETIRED
Joe Bob's Avatar
yes....they should have the same sized fasteners unless it's an updated one piece version.
Old 11-21-2009, 08:20 AM
Got them off
thanks for the help - for those trying the same thing here is what you need to do:
There is a gasket shown here in white that has to be removed. It's like glue. I did as recommended and just used a chisel directly on the white gasket area. Don't be shy, hit it good.
then, take a big screw driver and wedge it in the gap from the gasket and pry the roll pins out. work your way from one side to the other
Sean
NASA GTS2
Old 11-22-2009, 07:44 AM
Success! Thanks for the help.
Sean
NASA GTS2
Old 11-22-2009, 01:16 PM
RETIRED
Joe Bob's Avatar
Good for you.....A BFH is a good tool....
Old 11-22-2009, 01:56 PM
For those interested - I got the clutch cable off by hammering out the clip that was set in the case. You drive it towards the back of the car.
Sean
NASA GTS2
Old 11-22-2009, 04:11 PM
