Reverse Lights do not come on - I need a little help
I checked the bulbs, they are okay. Can anyone post an image of the reverse light switch at the tip of the transmission that I've read about but cannot identify when I'm under there looking up?
Where is the fuse and or relay located as well?
Thanks --- Rob
Old 11-21-2009, 05:42 AM
kodioneill's Avatar
It's #1 in the diagram sorry can't see the number 1 but it's in the lower left corner
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-21-2009, 05:51 AM
grateful user
don gilbert's Avatar
rob, get a test light, put car in reverse (key on, not running of course) and put it on the bulb contact in the housing. The connector comes unplugged from the switch easily to, go check that. worst case, sombody left the pin out that actuates the switch on a trans rebuild previously.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 11-21-2009, 06:08 AM
1980 911 SC
Don't mean to steal the thread......
has anyone had that pin get stuck and not allow the backup lights to go out? After a tranny/engine re-install my backups were always on. Had to dis-able wires to turn it off.
Life's a Beach
Old 11-21-2009, 06:35 AM
I've heard of that and the opposite, the pin wears down and does not make contact when reverse is engaged.
Old 11-21-2009, 07:06 AM
david dolan's Avatar
Thanks --- Rob
Here's a few pictures I nabbed from another thread here somewhere, I'd give credit to the original poster if I could now find the da%& thing. Let us know what you figure out.
David Dolan
1995 993 Carrera 4 India Red
1979 911 SC Targa Metallic Black
Old 11-21-2009, 01:17 PM
Does anyone know where I can find new plug pins for the switch? The wires broke to the switch and really would like to cut the wires and solder in new pins. Cant seem to locate these speciality pins....
Old 04-12-2010, 05:59 PM
Tired Member
DaddyGlenn's Avatar
I had the same issue with mine. Our host has the pins. Do a search or give them a call. It is an easy repair.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 04-12-2010, 06:15 PM
Ill call in the morning. Thanks for the tip, I forget that PP has more than their website...
Old 04-12-2010, 06:21 PM
Wire connection and test locations.........
Thanks --- Rob
Rob,
There are several locations where you could do your preliminary investigations. These are the locations:
1). Back-up light switch at the end of the transmission housing. Access through the chassis tunnel or above the transmission mount. Not convenient access.
2). Back-up light sockets with the transmission in reverse and ignition ON.
3). Open up the 14-pin connector located at the rear engine fuse panel. Locate pin #5 with yellow/green wire. Chassis side goes to fuse #11 and the engine side goes to F4 (back-up light switch).
Old 04-12-2010, 06:23 PM
Does it matter which wire plugs into which hole on the switch?
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 06-27-2011, 05:38 PM
Tired Member
DaddyGlenn's Avatar
nope
Glenn
Old 06-28-2011, 05:09 AM
