nkotselas's Avatar
Custom Exhaust vs Brand Name
Hi all,
I've been very interested in exhaust upgrades lately. I am planning on a euro premuffler and muffler. I was leaning toward M&K because I haven't heard a complaint yet. I just had a couple questions.
1. I haven't seen any reported gains from an M&K muffler, does anyone have any info or numbers?
2. Exhaust shops around town have quoted me between 15 to 20 horsepower with a new muffler, I doubt these numbers, but is it possible that a exhaust shop could get considerably more than a brand name muffler?
3. Anyone have preferences or experiences with custom vs brand name shops working on our cars? I don't like letting inexperienced people touch mine.
Thakns
Nick
'78 Turbo Look w/ euro 3.2
Old 07-19-2011, 10:52 PM
Member 911 Anonymous
DRACO A5OG's Avatar
My take, you will gain a little top end HP but will lose low end torque when you open up your exhaust. You may experience some gurgles and back fires but very little, sound is deeper.
In fact was going up an onramp with a bridge overhead, damn she sounded great
I would look into a sport cat with 1 in 2 out, if I had to do it again that is what I would do.
I have my old cat, but like my top end HP.
'85 Carrera Targa
PCA/POC
Old 07-19-2011, 10:58 PM
a.k.a. G-man
Geronimo '74's Avatar
1 M&K is good stuff, I'm sure dyno numbers are around. Maybe ask Ben (ben@mkexhaust.com)
2 If your muffler shop could get 20HP gains with just a muffler, They'd be makeing millions by now. They can't. (K&N airfilters don't give 15 HP either )
3 sorry, I'm too far away
Old 07-20-2011, 12:22 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
go for SSI's and an M&K. very nice combination for our cars. you could even talk to Rarlyl8. I think that is his username. He does a set of headers with a larger diameter that may be even better than SSI's for your engine.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 07-20-2011, 04:01 AM
IROC's Avatar
In the "dollars per horsepower" ratings, simply changing your exhaust is typically not a great investment. You can change the sound of the engine very easily, but getting much in the way of power gains over what the factory did is difficult. Those guys weren't dummies.
I've had seven different exhaust configurations on my car and none of them have made a noticeable power difference. They sure do sound good, though.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 07-20-2011, 04:17 AM
tobluforu's Avatar
You have not searched if you have not read a complaint about M&K, but if that is the muffler you want then check the classifieds because it seems they go on sale every other week.
20hp, good luck with that.
Old 07-20-2011, 04:19 AM
a.k.a. G-man
Other than the occasional droning issue with M&K dual in dual out mufflers, you won't find many malcontent customers. (there are of course the wives that complain that some of the mufflers are too loud for them.)
But these two issues are not specific to M&K mufflers at all. Almost all dual in dual out mufflers are prone to droning.
And if there are any issues, you'll find that they have a good customer service. (that you can also read after you search the forums)
20HP is very optimistic for a muffler only, true dat.
Old 07-20-2011, 05:12 AM
cycling has-been
bkreigsr's Avatar
M&K knows only one way to make a muffler - loud.
So, be sure you can deal with it before you invest. (- that's the main reason they appear here on the FS forum fairly frequently.)
I have one on my 85,(GT style, 1-in-2-out, center exit) and am very satisfied with it, but after several neighbors complained, I only use it on track days (it's 15 lbs lighter). Changeover takes about 15 minutes.
Bill K
Old 07-20-2011, 05:40 AM
tobluforu's Avatar
Agreed to a certain extent and I'm only referring to the dual out muffler which is painfully loud. If you want one of the lightest mufflers, one that looks the best and is loud as hell, then MK is the way to go. But, on my 72 I lost power with this muffler and no amount of tuning helped.
One other thing in regards to custom built mufflers, I built one for less than 200 bucks, is not very pretty, but does not drone and added top end, lost low end. So building your own is cheap and is known to work, just do a search.
Old 07-20-2011, 05:48 AM
Northern Motorhead
wildcat077's Avatar
Nick,
I've had my Fabspeed one in,two out muffler on my 89 for three years and i'm totally satisfied with the build quality and sound of this muffler. NO droning at all and great sound ... Cruising on the highway at 3000 rpm in 5th gear is very pleasant compared to some cars with "other" mufflers !
Although i have the MK Euro "pre muffler" as well which i find is a good complement to the system.
You will get all sorts of opinions but in the end,you get what you paid for ...
There are cheap mufflers that make a lot of noise or there are more expensive well built units that will give you,in the long run way more value for the money !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-20-2011, 06:11 AM
cdrik915's Avatar
For a simple muffler , Fabspeed can be ok , but for a complete RSR set , headers + muffler , go away from this brand.
We are two mates , we had bought the same complete set , and we had the same insolvables issues with it.
Nothing was correct with fitting : no correct aligment of the muffler , heaters ways out welded in the wrong way , leaks at the cylinders.........................and an after-sale conform to theirs products : Zero.
2490 euros .
Without any accessories , clamps , ducts for heater ways out.........
We've both gone with Dansk finally.
Just our opinion , with experience.
LIGHTER = FASTER !!!
Old 07-20-2011, 06:25 AM
I posted this a few years ago. Still very happy with everything.
Magnaflow Custom muffler made for SSi's and Dual outlets.
Old 07-20-2011, 07:43 AM
There's an archived thread on the Early 911S Registry forum where an engine dyno test was conducted on a rebuilt engine with 4-6 different mufflers (factory, sport, Dansk, aftermarket, etc.). YMMV as engine configurations will vary.
Look up Ray Crawford (RC70SCoupe). Here it is:
OPEN HOUSE: Engine on a Dyno
Sherwood
Old 07-20-2011, 11:27 AM
nkotselas's Avatar
Thanks for all the advice.
Ideally I would go with SSI but the budget and CA smog laws don't allow that, and it wouldn't be as easy to change every two years like a pre muffler or a bypass.
Sound is not necessarily an issue, I was planning on going one out to be easy on the neighbors, I do see 2 outs for sale in the classifieds quite often so those may be too loud for my anyways.
Would just getting a euro premuffler be the best choice? I already have a SW chip programmed for a euro spec 3.2, which wasn't meant to have a clogged cat as part of the system.
Nick
Old 07-20-2011, 11:36 AM
Northern Motorhead
wildcat077's Avatar
I have the Fabspeed dual out muffler with the MK "pre muffler" and the SW chip and i can tell you it makes for an excellent combination ...
If you read through numerous posts you will find that headers on a 3.2 don't give you much of a horsepower gain as compared to headers on a 3.0 Porsche !
Just sayin ...
Cheers !
Phil
Cheers
Phil
Old 07-20-2011, 12:22 PM
Consider a gutted stock muffler. Sounds great.
Old 07-20-2011, 03:52 PM
