OHMYGODTOTALHYSTERIAFREAKOUTIMLOSINGITRIGHTNOW!!!! !!!!!!. Calm down, ditch the exclamation points. Use caps when appropriate. Everything will work out. Good luck. --- Tom '75 targa |
got home at about 6. motor out.and teardown begun!!rocker arms not broken.so far cannot find and problem.tech will not be able to continue till monday of next week.hoping for the best!! everyone have a happy Thanksgiving!!http://forums.pelicanparts.com/uploa...1259199339.jpg
OK!! Can't wait!! Looking forward to finding the issue!!! happy ThANKsgIVIng!!
Oh wow!! You know what!! The motor not only thing being up locked!! You looking also at keyboard!!! It locked up too!! On explanation point!!
Folks/!!
That's a great photo John. What I see is a nice, clean, iron-barrel original 72T motor. To casual observers, the slightly rusty look gives them away. Is it matching numbers? More pics please. I don't wish to sound mean, but I'm betting if you wrote a little more clearly then this could be a nice thread to follow. When I mean clearly I'm talking the basics: full stops, paragraphs and all that. I'm sorry for having to point that out, and am far from perfect myself SmileWavy |
little humor there. exclamation point, but not...
On the other hand, I smell another UncleBilly...err...I mean "Vageen". |
Fwiw, I called Vageen out, knowing I may face the wrath of Dempsey...!! !! !!
Or worse, a ban from Nostatic :eek: |
In one of those pics, It looks like it had an engine fire.
BYW: I have no patience for the attitude of this guy. Something smells here. |
yes the tech said motor had an upgrade of tensioner which was a good sign .. numbers do match so would be nice to keep everything matching. seems to me once i get this motor rebuilt nothing else could go wrong.if anyone has heat exchangers for sale give me a private email with photos. if i decide to rebuild might as well go all the way.heat exchangers must fit 1973.5 carbsSmileWavy
Hey, just a thought, but while you're in there......................
Happy Thanksgiving everyone!!!!!!!!!!!!!!!!!!!!! |
johnm, What is your engine serial #? If this is a 73.5 it should have had CIS injection, not carbs. Updated pressure fed tensioners look like attached pic.
Matt Smith, 73.5T originaly had iron barrels.http://forums.pelicanparts.com/uploa...1259245690.jpg |
yes the carbs are not original. i never said the carbs were. the tech mech said my tensioners are an upgrade and within 10 years. i personlly are no pro on these cars and thats why it is a pros-shop. i'm only relaying what he told me.once he rips down the motor we will know what happened and the cause. the tech checked the numbers and said it was the original numbers on motor.
think about hot rod mods since you have to tear it down anyway, you may as well build it up good.
carb type cams are one thing to be sure of for more $$ could build to a 2.5L or 2.7L sorry you had this happen, but your fixed motor could go 200k miles |
And the update on the teardown is...?
| All times are GMT -8. The time now is 10:46 PM. |
