First Engine & Tranny Drop!
Hello,
First of all thank you to all who helped me prepare for this! The engine and Tyranny drop went great! All I have to do is raise up the car more and their free! I'm going to do that tomorrow....I'm pooped. Once i get them clear, I'll separate the tyranny from the engine and begin to dismantle the engine in preparation for replacing broken head stud bolts...among alot of other stuff. Just wanted to let everyone know I got er out!!!!!!!
Thanks!
Alan
Old 11-28-2009, 04:06 PM
1966 - 912 - SOLD
lane912's Avatar
good job!
Old 11-28-2009, 04:08 PM
nice work. if u have trouble getting that thing high enough try removing the panel on the side by the bumper. i was able to sqeeze mine out through there
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 11-28-2009, 05:48 PM
Hi, Thanks for the info! I tried to get the lower portion of the bumper off but the screws wont budge...I'll try to get it higher but if I were able to remove those screws it would make life alot easier......Will tackle it tomorrow.
Thanks!
Alan
Old 11-28-2009, 05:57 PM
I'm here to cause trouble
jimbauman's Avatar
I'd remove the rubber bumpers, and then take whatever time is necessary to remove the screws that hold on the valence. Seems safer then jacking the car up as high as it would need to go to clear all that....
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 11-28-2009, 06:01 PM
I'll remove the bumpers and get the lower portion of the bumper off.....somehow get those screws off. Thanks for the advise.
Alan
Old 11-28-2009, 06:53 PM
kristan's Avatar
Bumper removal
I would recommend removing the whole bumper.
It gives you at least 8 more inches.
To do that you have to remove:
- 2 screws holding the rubber strips
(if those are stuck an impact driver might help)
- 4 screws for the license plate lights
- 4 small nuts on the rubber bellows
- 4 nuts holding the bumper.
voila! the whole thing falls on your feet.
(I tied some wire to the license plate wire and threaded it through
the hole in the rubber bumper. Makes reassembly a lot easier.)
This is what it looks like:
1981 Pac blue SC 3.2L
Old 11-29-2009, 12:53 AM
Throw it on the ground!
No need to bother with removing rear valence or bumper. Just put some wood blocks under your jack stands to raise the car up. Plenty of room here using two layers of 2 x 10's.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-29-2009, 05:32 AM
Thanks for the info and pics it helps me out alot! I think ill try to raise the car a little higher first. If that doesn't work then off with the bumper. Hope to have time this afternoon.
thanks again!
Alan
Old 11-29-2009, 06:34 AM
