MdR MdR is offline
'69 warmrod T
MdR's Avatar
Question std 3.0SC on carbs in a '69T
I'm going to be fitting a standard '83 3.0SC engine & gearbox into my '69 911T with SSIs and a two in one out s/s exhaust. The T currently runs a later 2.4T & Zeniths.
I'd much prefer the look of carbs - I'm not after max h.p. or great fuel economy.
Given that I'm not made of money what would you suggest I need in the way of carbs?
Martin
DDK
Martin Rogers - West Sussex, England
+44 (0)7812 167547
Old 05-24-2010, 04:27 AM
Less brakes, more gas!
euro911sc's Avatar
Gearbox may have trouble fitting. Best to keep the original box and just swap the engine. Then sell the 915 and recoup some $$.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-24-2010, 06:20 AM
MdR MdR is offline
'69 warmrod T
MdR's Avatar
Question
Thanks for the reply - what will be the gearbox issue?
DDK
+44 (0)7812 167547
Old 05-24-2010, 06:58 AM
ckissick's Avatar
I have a 3.0 with Webers in my 1970 911E, and it looks and works great. PMO carbs would probably be the best choice, as they are new. I think PMOs cost less, too.
I'd also keep the old tranny. I don't know about fitment issues, but I like the idea of keeping the original, vintage shift pattern.
Wiring is significantly different, and it took me a while to figure it out when I put the engine in. I think your wiring would be the same as mine. PM me if you need to know about wiring.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 05-24-2010, 07:21 AM
Home of the Whopper
The wiring is quite a bit differnet between a 69 and a 70. A 69 is a PITA. But with carbs it iwll be much simpler.
Do a search for "zeniths". some body on here is selling venturies for a 3.0. They will work fine if you set them up properly.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-24-2010, 08:48 AM
euro911sc's Avatar
I believe (no experience myself) that you have to pound some sheet metal to get a 915 to fit in place of the 901. Nothing as serious as replacing metal to get the G50 to fit in non-G50 cars. But, the metal around the nose cone will have to be persuaded to allow the 915 to fit with clearance.
Best regards,
Michael
'13 Cayenne GTS
Old 05-24-2010, 09:03 AM
MdR MdR is offline
'69 warmrod T
MdR's Avatar
Thanks euro911sc - I've fitted a 911/01 'box to a 1951 Bug so I do have a big hammer
Thanks BK911 - Zeniths? Hummmm. I hadn't even thought of using them. Previously I've heard nothing but bad things about Zeniths.
DDK
+44 (0)7812 167547
Old 05-24-2010, 09:09 AM
Senior Advisor
James Brown's Avatar
Check out a conversion I did about a year ago to a 3.0 to Zeniths changing the jets and ventures. Great carbs and now a great car! Only minor tuning issues (mostly ignition). Best thing is there dirt cheap to buy compared to Webers and PMO's.
08 Cayenne Turbo
Old 05-24-2010, 09:52 AM
MdR MdR is offline
'69 warmrod T
MdR's Avatar
Arrow
Thanks James Brown I've had a look at your thread and it's helpful & informative to me.
Did you stick with the jetting as in your thread?
Can anyone suggest & availability of vents & jetting for Weber 40IDS carbs?
DDK
+44 (0)7812 167547
Old 05-27-2010, 03:39 AM
