Footwell blowers squeaky, how to fix.
My turn to contribute to this forum.
My car, 88 911 coupe. I have those squeaky footwell blower motors. I decided to try to fix them before spending big buck for replacement. It turns out to be pretty easy. Here's how: 1- Remove the motor assembly from the car ![]() 2- Remove the screw at the top of the assembly and remove the cover. ![]() 3- Remove the 4 little clips to release the bottom part. ![]() 4- Here's what's left. ![]() 5- Using a tiny flat screwdriver, gently remove the shaft retaining clip (not sure how it's called) by moving up each tooth one at a time. The clip will come out. Although it's not necessary to remove it, I found that by doing so you are allowing the motor shaft to move 1/8" up or down in the housing helping lubrification. ![]() 6- Remove the clip and washer. Remove the 2 screws that retains the motor from the plastic housing. ![]() 7- Flip the assembly, take a small flat screwdriver and gently pull the squirrel cage up. The cage is press fit, so it will come out the shaft. ![]() 8- Cage removed ![]() 9- Flip the assembly again. Put the shaft on a flat surface and using one hand on each side of the plastic housing push downward. Motor will come out of the plastic housing. ![]() 10- Pull the motor completely out of the plastic housing. See the crap at the end of the bottom arrow. Noise is probably coming from there. Clean and lubricate each side of the motor shaft. If you previously removed the top clip, you'll have 1/8" to move the shaft up and down allowing the oil to go in. ![]() Reassembly is reverse. It takes maximum 10 minutes per motor and saves you big money.
Ian 88 911 coupe + nice upgrades |
This is cool - Thanks!
I got used to them squeaking but I'll add this to my to-do list.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
very cool post!!!
I had bought new (used) motors which also squeal, I'll give the fix a try and may have some motors for sale!
Dietmar 1987 911 Carrera 2008 RS 60 Spyder |
What perfect timing, Thanks for the help.
Karl 88 Targa |
+ 1 on the procedure. I did something similar a few weeks ago. Worked great.
Weekend Mechanic
Fantastic tip! I have squeaky blowers as well so you've given me yet another winter project to keep me out of my wife's hair :-)
86 911 Carrera Targa
ok just finished one! NO MORE SQUEALING!!!! This is an awesome fix!!!!
it took me 29 minutes for one motor, I kept double checking everything, blew it out with some dust remover air, degreased it and then lubricated with some bicycle teflon spray. It runs like a charm, just a hummm from the fan, can't even hear the motor any more at all!!!!!
Thanks for this great post!
ok I am starting the 2nd one
ok 2nd one finished!!!!!!!
7 minutes this time!!!!
this is great!!!
One of my new (old) motors that I had bought was stuck, it did not run at all, just made a hummm, now it also runs perfect. I am glad I did not throw these away!
Sorry to be redundant, but I just looked up the price for a new motor, one of these goes for $182.50!!! plus shipping. Used ones 103.89 at German Dismantlers!
Thanks so much again!!!!
I performed this procedure on my motors last year. It didn't work for one and the other lasted a year and is now screaming. This can certainly keep things cooking along but does not address the ultimate wear and eventual seizing failure these motors go through.
1988 Carrera Coupe |
yes,..that's exactly what I do, albeit preventatively.....the frikin wear points will eventually come to fruition........with time...
The work done certainly extends their life. Good work!!
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Have these been improved since '84? I remember a plastic squirrel cage and a plastic housing, and when the bearings got loose the cage rubbed and friction welded itself to the housing. Acrid smoke, since even this kind of dead short did not draw enough amps to blow the 25 amp fuse the diagrams say is in line.
Walt Fricke |
This maybe the wrong place to ask, but my footwell blowers just broke tonight. Some sort of short in the dash, and now they just stay on. I had to unhook the battery to get them off.
Has anyone seen or heard about this this problem before? I didn't find it using "search" |
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 12-04-2009 at 05:07 AM.. |
Thank You. I had no idea what you were talking about, but I opened the trunk and fixed it using your instructions. ( First Porsche, first problem, First problem solved ) I will be adding these forums to my quick links bar, ha! Best, Steve Last edited by Zether89; 12-04-2009 at 11:47 AM.. |
How long is this lasting for you guys? I dissembled mine and oiled them last year and they were quiet for about 2 days, how often are yours being used?
