Unhappy how do I know what size torsion ars I have
Dumb question ,after searching
I am trying to identify what size my rear torsion bars are on my 1985 Carrera
Color Black
circumference 7.5 cm
two white marks on them and two green marks on the length of them
may be a dumb question but i would appreciate any help on this
Old 12-10-2009, 01:04 PM
vash's Avatar
75mm/PI=23-24mm?
if you can measure circumference..can't you simply measure the diameter? sorry, i am arse deep into a huge spreadsheet, not seeing or thinking straight.
poof! gone
Old 12-10-2009, 01:25 PM
Tim L's Avatar
the math = 23.7 mm
Tim Lynn
84 911 Carrera
PCA E Stock #278
moneymanager's Avatar
Measure. A 23mm bar is 23mm in diameter.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 12-10-2009, 01:26 PM
MattKellett's Avatar
If you don't have any calipers and only a tape measure or ruler, take 2 objects (sticks) and place them either side of the bar and then measure the distance between the 2 with your ruler - make sure objects are parallel.
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 12-10-2009, 01:30 PM
torsion bar
Thank you all for your help
I guess it time to start looking for stiffer T bars.
I appreciate the help as I did not know that it was based on he diameter.
Am I correct in assuming from my reading that
a 27/28 rear
and 22 front
would be a good all round street plus DE combination
The car is 85 sunroof carrera
AC delete
CTR fiber glass bumpers Bilstiens all round
Thanks all Chris
Old 12-10-2009, 02:34 PM
Bill Verburg's Avatar
sounds to me like you have stock '85 18.8mm & 24.1mm t-bars
Bill Verburg
Old 12-10-2009, 02:44 PM
I think you are right Bill
I guess I will just lower it to Euro and start saving for stiffer bars
Old 12-10-2009, 02:53 PM
Lynn,
If you have it apart it is a good idea to freshen the bushings and do what you want to as the cost of alignment and reseting the corner balance can be expensive.
22/29 is a good sport combo for an 85 w HD/HD or HD ft/Sport shocks rear. New shocks lift the car.
Solid torsion bars are not very expensive. Something like $600. Shocks about the same. Plus bushings and about $1000 for a good corner balance, alignment, and fine tuning of the ride height.
Old 12-10-2009, 06:36 PM
