ibeaudoin's Avatar
Flare wrench size for brake lines
I'm getting ready to replace the brake lines on my car and I want to make sure I have the correct tools before starting the work.
I received some SS lines from our host and was a bit disappointed to see that the nuts on them are SAE and not metric. So I will need more flare wrench sizes.
Can someone tell me which wrench sizes are required? (Car is a 1988)
New SS lines will required 9/16 and 11/16.
I understand that the hard-line uses 11mm.
What about the OEM rubber lines, are they 14mm and 18mm?
Ian
88 911 coupe + nice upgrades
Old 12-10-2009, 01:18 PM
Peter Zimmermann's Avatar
14mm & 17mm...
Keep the Shiny Side UP!
Pete Z.
Old 12-10-2009, 02:15 PM
Best bet is to look at a set of 3 or 4 wrenches with different sizes on each end and be done with it. You will find a need.
Regards
Old 12-10-2009, 03:15 PM
ibeaudoin's Avatar
Thanks all
Ian
Old 12-11-2009, 03:07 AM
