Oxygen sensor connection in engine bay
I'm attempting to re-install an oxygen sensor on my 83SC (exploring some idle issues one thing at a time). The car has B&B headers installed by the PO and they do have the O2 bung - I'm looking for pics or a description of where the electrical connection is within the engine bay and I do have the female connector off of the sensor.
Thanks!
Mike
Mike S.
83 SC Coupe, Guards Red
Old 12-11-2009, 12:01 PM
grateful user
don gilbert's Avatar
mike, the original conn. is on the left side of the engine compartment mounted on a bracket next to the cdi box, If its still there, as most have been broken off. If it is broken, You can just cut off the damaged connector, strip back the shielding and recon. using a butt connector. DO not solder, as the solder can act as a resistor on the milli voltage traveling the wire to the ecm.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 12-12-2009, 05:13 AM
Thanks Don,
I also saw a picture of what the male connector looks like over in the classified section - with your comments I should be all set to go.
Mike
Mike S.
Old 12-12-2009, 06:17 AM
