Senior Advisor
Bosch 3.0 curve chart
Anyone know where I can find a gen-u-wine Bosch distributor curve chart for the 3.0L engine? Have a good idea what it should be but someone wants the real deal. any year will work.
08 Cayenne Turbo |
James,
You'll find that in the Porsche factory shop manuals. They are different for US & ROW as well by year.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Senior Advisor
Thanks steve. I'll pass that on.
08 Cayenne Turbo |
Quantum Mechanic
I have the factory shop manuals and found the distributor curves in section 9. See below.
I scanned the distributor advance curves for the 80 and 81 SC. The factory procedure for setting the timing is the same. -5 BTDC at 950 RPM with both vacuum lines connected. Given today's gas, I back this off to -3 BTDC. As you can see, the high rpm slope in the advance curve is at about 3000 rpm SHAFT SPEED which is 6000 engine RPM (Distributor turns at 1/2 engine speed). ![]()
Mark Petry Bainbridge Island, WA 81 SC Last edited by mpetry; 12-13-2009 at 07:29 PM.. |
