AKA SportsCarFan
FastCarFan's Avatar
Battery maintainer question
I have a Porsche battery maintainer (photo below). I hooked it up to the battery terminals & plugged it into a wall socket. Should the light on the unit be on, or does it only come on when it determines the battery is low & it is actually charging? I don't see a light & I am afraid it might not be working properly (which would explain the dead battery I had last spring!).
Thanks!
Doug Miller
1988 Guards Red Carrera
Old 12-14-2009, 08:31 PM
Send a message via Yahoo to chris.817
No experience with that charger but it's likely that the light should be on. Fuse blown in cigarette plug (it want to see a load before charging) or it's broken? Test for voltage out on the cigarette plug and check the fuse inside.
Chris
87 Carrera Coupe - Guards Red on black
00 Carrera Cab - White on Navy
05 Carrera S - Atlas Grey on gray
86 951 - India Red on black - Sold
Old 12-14-2009, 09:56 PM
Sorry. Didn't read the entire post. I guess you're not using the cigarette plug.
BatteryTender is a great product if you need a new one.
Chris
Old 12-14-2009, 10:02 PM
Don't know about your unit, but on mine, a Battery Tender, the red light comes on as soon as you plug it into an electric socket. It stays red if the battery voltage is below 80 percent of fully charged. It changes to a blinking green when the battery reaches 80 percent, then goes to solid green when the battery is fully charged. There is never a time when there is no light (other than if the unit is unplugged from the electric socket).
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-15-2009, 05:14 AM
If, by chance, you are using it by plugging it into the cigarette lighter socket, check to see if the light comes on when you insert the ignition key into the ignition and turn it to the first position.
JR
Old 12-15-2009, 06:19 AM
I have the same unit and the light only comes on when the battery is being charged. Once it's charged, the light goes out.
2012 Cayman R - Black/Black
1995 993 - Polar Silver
Old 12-15-2009, 08:12 AM
AKA SportsCarFan
FastCarFan's Avatar
Thanks. That's exactly what I wanted to hear! I knew someone would know.
Doug Miller
Old 12-15-2009, 07:10 PM
Leave your headlights ON for about an hour, then check the status of the charger LED.
The cig. lighter circuit could be inop when the ignition is OFF.
Sherwood
Old 12-15-2009, 11:41 PM
AKA SportsCarFan
FastCarFan's Avatar
Sherwood
The cigarette lighter circuit is "dead" with the ignition off, which is why I have attached the battery maintainer directly to the battery.
Doug Miller
Old 12-16-2009, 09:15 AM
Confirmed PAG left this circuit the same at least until '88.
Thanks,
Sherwood
Old 12-16-2009, 10:44 AM
