Home of the Whopper
2.2S teardown
I have been slowly tearing down a 2.2S engine. I was told this engine was sitting under a tarp since 1972 and had only one year of year since new. Here are some pictures. Please tell me if you think the engine could have been as described.
I am not sure what I am doing with it yet. It may end up in my 73.5T as a high compression 2.4S, sorta a 2.4S+.
The throttle shafts are just TIGHT. I need to take them apart to lube them up. NO slop at all.
Check out the gear on the pump. I dont see any wear. Cam gear looks the same.
Cam lobes look perfect. I didnt even wipe them down.
Rocker arms look as nice
Cylinder looks pretty good. very little wear. I will mic it of course, but looks good so far.
Heads were only wiped down with a rag. I will dis-assemble but look good so far.
I haven't split the case yet, but I like what i see so far. To my untrained eye the engine looks as advertised so far.
I would appreciate the feedback from those that know more. Whadda you think?
Thanks!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 12-22-2009, 10:33 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Looks pretty new to me, unless the cyl cross hatch isn't factory?
Gary R.
Old 12-22-2009, 12:20 PM
The rocker shafts have rsr seals in them, not something you would see in a factory engine. Also the rockers arms seem refinished, normally they have a fairly sharp edge, which in this case seems broken. In any case an interesting find
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 12-22-2009, 12:24 PM
When did Porsche stop using forged rockers in their "S" motors?
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 12-23-2009, 02:58 PM
