915 vs G50 trans
I have replces the shift bushings but my car still goes in to 1st rough and 3rd. I'm getting ready to pull it out and put a new clutch in but my question is. Should I look at having the 915 rebuilt or buy a G50 to replace it. Will the G50 biolt right up with out modification?
gearhead
tln,
You ask a very personal question and we know nothing about you. What year is this car? How is it used? What kind of miles are on the car and what is the known history of use? Regardless, going to a G50 is going to cost 2-3 times as much as rebuilding your 915.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
It's a 1984 911, has 85k on it, I drive it about 3 times a week
AutoBahned
either rebuild the 915 or sell the whole car and buy an '87
MBruns for President
or look for a 915 that's already been rebuilt, sell yours as an 85k mile example. Unless you are a ham fisted operator, 85,000 miles should not be to the point that it needs a complete rebuild. maybe check your bushings/adjustments first.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
gearhead
Though it wouldn't hurt to change the gear oil first. Something I see time and time again on low mileage cars like this is gear oil (and engine oil) that's been left in there too long. Regardless of mileage, I tell my customers to change their gear oil every 24 months maximum. I change mine once a year. Oil has a "shelf" life in addition to mileage limits with respect to breaking down. If the oil in there is 10 years old because the mileage on the box hasn't warranted changing it, get some fresh oil in there and see what happens. This will also let you inspect the drain plug and get a more empirical idea of the wear on the box.
There are many possibilities for your 1st/3rd problem, usually it's linkage, bushings, adjustment. Which "bushings" did you replace? Are you experienced with early 911 shift linkage? Is your coupler tight? Is you shift lever perfectly vertical when the car is in neutral?
Keep the Shiny Side UP! Pete Z. |
I bought some of the trans fluid from our host but have not changed it yet. I've only had this car for a year but love it. I'll try changing it and see if it helps. I'm afraid the syn are worn out on 1st and 3rd. Thank you for your input all. This site is very helpful
Look for Shell Spirax MB 90
Yeap,..fluid FIRST!!!!!!!!!!!
Then Pete Z's advice..... Then follow RWebb's advice next! Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia Last edited by dshepp806; 12-21-2009 at 01:18 PM.. Reason: content |
This is from a thread asking for advice in buying a 911 with a 915 or a G50:
Aaron '81 911SC RoW Targa |
greg79s
Remember that the G50 will add more weight to your car. I physically picked up a G50 with assistance recently and it was it was very heavy. Rebuilding the 915 would be economical way to go......I drive a 3.2 with a 915 (My car) and recently drove a 3.2 G50 (my father's 1987 ) The throw is shorter on the G50 and you use less energy to shift if that is what you prefer. I like the 915 better since is is lighter and has tha classic long throw shifting. You can do more with them at rebuild time if you want to make changes. Good Luck.
Information Junky
that's not right. Just fix it, and you'll be happy.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
can't stand the balky 915.......
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
LOL,..They are only baulky when:
1) Just worn out 2) Incorrectly rebuilt 3) Worn shift coupler & bushings 4) Wrong oil Combinations of the above. A properly done 915 is very smooth.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
my targa is very tight (58k original miles) and my other 911s had tons of miles on them. they have distinct personalities to be sure, but they are still a pleasure to own and drive. i say, buy one of each!
I probably wouldn't believe the rumor that they could be made to shift well, but my friends '81 SC shifts buttery smooth...Despite the longer throw, it may shift better than my G50! It has 80k miles on it, and to his knowlege has never been opened! The 915 can be fixed... but you will probably find there is no cheao or "easy" way out. Have it done properly! |
AutoBahned
what you really want is a 901/911 transmission.
the 915 is just too modern -- other than that, I agree completely with MRM |
