starter issues in a 2.7 to 3.2 engine swap
I switched from a 2.7 to a 3.2 useing my 76 915 trans and a sachs alu flywheel assembly I had put on the old engine. The starter spins but will not engage the ring gear. the total travel of the gear is approx 4cm. I measured the distance from the face of the starter mount to the face of the ring gear and it appears I need about 6cm of travel to completely engage the starter and ring gear. Is this a starter issue or does it relate to the flywheel assembly?
Would appreciate any Info.....thanks |
Are the starters the different on a 3.2??
The starter is the same for 74-89 but the starter RING GEAR is different. That might the issue holding you back.
I don't know the exact differences but here is info from the pelican catalog- Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Thanks Wayne......Looks like my engine is going to see the shop floor again
I thought I had it all sorted out seeing as how I as reuseing the Sachs flywheel setup, but something is different in the depthjack |
I too Replaced my 2.7 In my 1976 Porsche 911S with a 3.2 I had to use a 9 BOLT 3.0 Flywell. It works just fine.
well, maybe the ring gear is not there. the teeth on a 3.2 flywheel are not starter teeth. they are there for the sensor. the starter teeth go on over the pressure plate. just a wild guess.
More than a few persons have made that mistake.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
John....it appears that is exactly what I did wrong. I only have one set of gears on. The next question is does the order the gears are installed matter or can they only go on one way?
By the way...THANKS!!
