Uno Dei Molti Porschisti
BarryJB's Avatar
90A Paris-Rhone alternator spontaneously resurrects itself - can anyone explain thi
Deleted, see "Do Paris-" thread which is now content corrected, even though title is screwed up.
The original chopped off & unchecked "Do Paris-" message & title apparently got posted when for some reason I had to log on again to go advanced while I was 1/2 way through writing it.
Can't see any post delete option even going advanced when you hit "edit", just edit options, you can delete text in title box but it says you must leave 2 characters in message so no complete delete option that way.
This then my best attempt to delete it for now. Sorry for my confusion.
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024
Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon".
Old 04-18-2010, 11:51 AM
Delete this post? I answered the other one.
Old 04-18-2010, 12:27 PM
BarryJB's Avatar
Yes it should be but I haven't figured out how yet - don't see it in the thread tools... When I go to Preview a post - I often have to log in again and weird things seem to happen after that... like the incomplete post that showed up first. And thanks for response too. And darn I note another "it's" escaped my computer in place of an "its"...
Old 04-18-2010, 05:01 PM
Go to 'edit' at the bottom of your post, then there are a couple clicks to get the delete done.
Old 04-18-2010, 05:15 PM
BarryJB's Avatar
Thanks tcar, I found the "edit" button, but I still didn't see any "delete post" options, even though that button teases by popping up "edit/delete" on mouse-over. After hitting that button, even going advanced, I saw no explicit delete options, just editing ones. So I settled for editing the original post as above as my best attempt to kill it, at least for now.
There seems to be some sort of conflict as I am often unexpectedly required to log in again & again, and many times doing a message that I can't proceed as I'm already logged in occurs, or something circular & annoying like that. I'll have to chat with Pelican Tech Support, this is a pain to all.
Old 04-18-2010, 08:07 PM
BarryJB's Avatar
There seems to be some sort of conflict as I am often unexpectedly required to log in again & again, and many times a message shows up that I can't proceed as I'm already logged in, or something circular & annoying like that. I'll have to chat with Pelican Tech Support, this is a pain to all.
Thanks again.
Old 04-18-2010, 08:09 PM
Senior Advisor
James Brown's Avatar
you can't deleat the whole post but you can edit the text to say "see my other post ............"
08 Cayenne Turbo
Old 04-18-2010, 08:14 PM
BarryJB's Avatar
Good, that's what I ended up doing... thank you. It's a relief to know I hadn't overlooked another glaring button...
Old 04-18-2010, 10:12 PM
