Rotten Egg Smell
I have a 1976 911 Carrera 3.0. After the car warms up for about 20-30 minutes, a rotten egg smell fills the car. Does anyone have any ideas what might be causing this? I have great digestive health, so I know it's not me
Chain fence eating turbo
Possibly your voltage regulator is cooking your battery by overcharging.
Another possibility if your car has a cat would be a horrible rich fuel mixture and an overheated catalytic converter.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I experienced this with my voltage regulator going south as well.
I experience the exact same thing in my 1984 Carrera 3.2, but not all the time. At first, I thought it was a dead rodent stuck somewhere under the 911 but nothing was found.
The smell only occurs after being parked outdoors and on a slight hill. It happens immediately after start up and only lasts a few minutes. It never occurs when I'm parked in the garage. I've installed a CAT by-pass but the smell still occurs, so it's not the catalytic converter. I suspect it's condensate that collects after exhaust system cool down. The condensate may be reacting with some of the fuel's residual by-product ( small amounts of sulphur?). Just my theory of course.....sometimes I just open the windows. If the smell fills your car after 20 or 30 minutes of running as you describe, I'd check for exhaust leaks entering the cabin, you may have a leak after your CAT.
Ray 1988 928 S4 5 speed "Loud Cars Save Lives" 1984 Carrera 3.2 coupe "The Mistress" Last edited by S4hounddog; 12-10-2014 at 09:41 PM.. |
ROW '78 911 Targa
Check the voltage at the battery when the car is running and post your result.
Do it in a well ventilated area and try not to create any sparks.!!!'
Voltage Regulator
+1 on Voltage Regulator.
With the engine running, the voltage at the battery needs to be watched for a couple of minutes and at various RPM's, as a failed/failing regulator may cause surging between normal and abnormal charging levels. As I recall 14 Volts @ 2500 rpm is normal charging voltage. |
Amazingly enough a FAILED alternator can boil the battery electrolyte..!
Shorted or open a stator segment, the VR "pumps up" the output in order to have the average voltage output be in the correct range. The VR does not "see" the (remote, "filtered") battery voltage, only the high ripple content alternator output. CDI often fails due to the "local" over-voltage. Last edited by wwest; 12-11-2014 at 10:33 AM.. |
Skunk works
Been there, done that Although it would probably only happen once and the next time you went to start your car the battery would be dead aren't you more likely to get a smell with no cat?
964 RS-4 |
Voltage regulator cooking battery BTDT.
83 911 Production Cab #10
Me too and you don't want to breath that for too long.
Cheap way to monitor you battery short of having a permanent voltmeter instal. Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
The other possibility may be that I bought the 911 with a bad CAT and the odour is same with or without?
Ray 1988 928 S4 5 speed "Loud Cars Save Lives" 1984 Carrera 3.2 coupe "The Mistress" Last edited by S4hounddog; 12-17-2014 at 12:16 PM.. |
