brooklynporsche's Avatar
BMW Roundel Need some help?
I just found out that the transmission in my 1981 Porsche is from a 1974 Porsche part# 915 301 101 0R. I need a 915 transmission that will work with a 3.0 Engine.
What are my options? I was thinking to sell it or trade for another working transmission. How much does a 1974 transmission go for?
Thanks in advance
Old 12-28-2009, 06:01 AM
SC-targa's Avatar
The 74 will work fine, but does not support the electric speedo in your car. It has a lighter mag case and a shorter final drive ration that many like, but goth are less robust than the later aluminum case unit.
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 12-28-2009, 07:00 AM
Thanks SC-targa
Are you saying that I should go ahead and keep the tranny. Also is this 5 spd or 4 spd
Old 12-28-2009, 07:10 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I was under the impression that the 74' 915 transmissions had the 7.31 ratio which I have read "feels like adding 50hp". With that in mind, it might be beneficial to find a gear driven tach and enjoy the short gear ratio
If not, you could probably work out a trade with someone wanting to upgrade...
Personally, I would keep it.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 12-28-2009, 08:09 AM
I was expecting the worst. Original someone sold me the car with a 2.4 CIS engine. Once I found out I was extremely disappointed but everything worked out I was able to sell the engine and get me a 3.0 engine. Now you guys are telling me that the tranny will work and in addition will add more HP. WOW that sounds good. Thanks Kemo
Old 12-28-2009, 08:24 AM
Black and Blue
Kemo's Avatar
well, technically, the 7.31 doesnt add any horsepower, it just makes good use of the gears. I think you might lose a little bit on top end. Bruce Anderson has written a really good book on getting horsepower out of 911s. So if you get a chance, pick up a copy of his Performance Handbook. Its a great read...
Long story short, if you want good performance from a stock 3.0, get the SSI heat exchangers with a cool muffler. Combine that with the 74 transmission and you will have a fun, reliable car.
post some pics as you go along if you get chance
Kemo
Old 12-28-2009, 09:40 AM
I will thanks Kemo. The project is still a long way from being finished.
Old 12-28-2009, 10:18 AM
AutoBahned
RWebb's Avatar
keep it and maybe modify it if in good shape
search up the Best Year for a 915 thread for ideas on strengthening it & think about changing the gears a tad for best performance.
The earlier (Mg cased) 915s are lighter, which is what you want in a sports car -- as long as nothing breaks.
You need to think about your goals for the car...
I have a 3.2L hotrodded motor with a '75 trans. When I get a lot of $$ I don't need I may change the gearing a bit, but it is not too far off right now.
Old 12-28-2009, 12:06 PM
No, that's not what they're saying. The transmission cannot ADD horsepower.
The car will feel more responsive on acceleration due to the lower gearing. This will be fun. (Like adding HP out of the chute.)
The top end (top speed) will suffer a bit as a result. At top gear redline the car may be 5 or 10 mph slower with the early transmission.
Also, cruising on the highway, the engine will be revving higher and noisier if that bothers you (wouldn't me).
I would keep it.
Hmmm, the 2.4 CIS motor is a '73.5 on a '74 tranny. Interesting. Wonder if it's from a late '73.5 with the '74 tranny.
Keep it.
Old 12-28-2009, 04:29 PM
thanks guys. I'm also in the process of rebuilding my 3.0 to a 3.2 short stoke twin plug and adding SSI heat exchangers. Will this work?
Old 12-28-2009, 07:37 PM
AutoBahned
RWebb's Avatar
yes, but depending on your revs & usage, the SSIs may be a bit confining
they should be fine for a street motor
Old 12-28-2009, 08:17 PM
Yes definately a street motor. RWebb I'm curious what would you recommend instead of the SSI? Headers
Thanks again
Old 12-28-2009, 08:24 PM
