Banned
1973 porsche 911t/tech blew motor and i want to know how i tell if he was at fault
bought a Porsche 911 t/removed tank and had it boiled and sealed/then bought to garage since i couldn't rebuild the carbs but before he did it had motor compression checked which was fine/garage rebuilt carbs and car ran fine for over an hour/took car for ride and heard noise in transmission which tech then dropped entire engine with trans and found that noise was just loose nut on reverse that loosened/while then tech replaced rear seal on engine and told me i needed a new clutch which i went for/tech puts everything back together and i tell him i will be picking up/he says i want to tune for perfection and to call him following day/next day out of the blue he calls me in the morning and says motor just seized while running outside before he took for another test ride!!!tech has had car for over 6 months and i think he caused the motor to seize//how do i know if it was his fault?? i have an that somebody forgot to take out plug of hose when reinstalling motor of oil supply!! tech says he feels bad and wants to rebuild motor for 5 grand[25 hours labour and appr 2500 parts ]!! what should i do!!!new to Porsche ownership!!
Old 11-24-2009, 05:05 AM
Almost Banned Once
sc_rufctr's Avatar
The tech sounds like a good guy.
Sometimes these thing happen and there's not much you can do to prove anything was done incorrectly. He is human after all.
What to do? That's a hard one. Go and talk to him face to face. Get the car fixed and learn something from the experience.
- Peter
Old 11-24-2009, 05:59 AM
why exactly did it seize? was it worn out to begin with and he was just unlucky enough to be the one driving it when it went south, or did he not put oil in it? some things are just coincidence, nobody's fault.
206 637 4071
Old 11-24-2009, 06:43 AM
daily driven 911
i would GO look at it and figure out what is going on......ASAP....
Old 11-24-2009, 06:55 AM
One of the reasons shops sometimes keep a car a long time has nothing to do with incompetence, and I've had my '83 SC sit in the shop--or outside it--for months at a time to get some relatively minor work done. (I try to make sure it's wintertime, not the middle of the summer.) Independent shops typically have lots of customers with daily drivers, whether they're 911s or not, and they know when a customer's car is a toy and when it's something he needs in order to get to work.
My car is a toy, and so, I suspect, is yours. A tech will work on drivers to get them out the door and back into service and will perforce wait for a convenient time to tear into a toy.
You have "over $3,000" in the car for the work you listed? Sounds like a bargain.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-24-2009, 07:02 AM
Could I suggest that you make friends with the spacebar and lose the slashes and screamers (otherwise known as exclamation points)? They make your posts so hard to read and interpret that I've stopped bothering.
Stephan Wilkinson
Old 11-24-2009, 07:13 AM
From the few pictures you posted it's hard to tell the value of your car but from what I see, if there are no rust issues, you definitely have a car worth your potential new outlay.
I agree with the others, failure of an old, unknown engine can happen to anyone. It sounds like your tech is honest and open and reasonable in his charges. Talk to him, face to face as others have said. Learn of the potential causes of engine seizures. Lack of oil is certainly high on the list but that doesn't mean there was no oil in the engine--it's the circulation and pressure that matter. Maybe you can get a written commitment to a specific rebuild price that would make you feel better, along with the mileage warranty. Putting $5K into a quality rebuild is very reasonable, IMO, and you would still not be upside down on your "investment" if the car is truly as nice as it looks.
One point to consider. If the 2.4 is not original to the car, that may be a factor in considering an engine swap as there is a greater value in matching # cars. Even if it is a matching # engine, you may wish to invest in a swap and keep the original for later rebuild. Regardless, the engine should remain with the car, if original, to maintain value.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-24-2009, 07:37 AM
mca mca is offline
mca's Avatar
Nice looking car!
I spent roughly $6k rebuilding mine (I did the labor). It quickly escalated to $10k when I got SSIs, new muffler, fuel injectors, etc etc.
You have the potential to get a full rebuild for $5k plus a 1 year warranty by a pro. Great deal! On top of that you already addressed freshening up the fuel system. At the end of the day you will have a brand new motor / brand new system ... you can drive worry free for years!
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 11-24-2009, 07:45 AM
well, you won't get a first cabin rebuild for $5K, you know that? rings, bearings and a valve grind maybe. that's on a running, undamaged engine. yours is seized, which may well have damaged crank and/or case, of more. best to do the teardown before doing the estimate.
206 637 4071
Old 11-24-2009, 07:57 AM
With all due respect to everyone here, let me be the voice of dissent and say that in my opinion, there is no reason that a motor should seize after a qualified talented independent Porsche mechanic has just completed any major service/rebuild/whatever on that engine. An engine that seizes before it arrives at the mechanic's is one thing. An engine that seizes 5,000 miles after a rebuild? Another. But the guy worked on it for 7 months and it's in his possession when this happens? Oh no. It's his fault for killing the patient and now he needs to make this right. Would I pay him a dime for his work up to this point? Nope. I'd pay for the one rebuild I asked for originally, even if it takes this guy two times to do it. I agree that a very long face-to-face conversation needs to take place when you two create a game plan to fix this mess. All the next steps need to be in writing, with guaranteed prices, with both your approval signatures clearly visible. Sorry to hear about your nightmare. Good luck.
Sandy
1969 911E
1970 240Z
Old 11-24-2009, 09:22 AM
x2 wanted to make sure everything is perfect? and seizes it ????
Old 11-24-2009, 09:56 AM
mca mca is offline
mca's Avatar
Why did the car sit for 3 years? Knowing this might shed a lot of light on the situation.
Old 11-24-2009, 09:58 AM
T77911S's Avatar
he just bought the car. you dont know what or how the PO did or treated the car. perhaps the PO new something was wrong and unloaded it. at 5k it sounds like it may be the PO's loss.
beautifull car. if it is not a rust basket case, it should go for $25k+ easily, if all original and in good shape 30-40k. the long hoods are getting rare, and an orginal one is worth even more. 5k for that car with a bad motor was a deal.
do the motor right, if you decide to sell, it will be worth it.
it looks like a pretty big and nice porsche shop from the pic so that is encouraging.
you can ask to be there for the tear down or even ask if you can do it at the shop. that is a good way to learn about the motors.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-24-2009, 10:06 AM
Point well taken, but doesn't fit this scenario, IMO.
There is no indication of any rebuild work being done on this engine, either by the PO or the current mechanic in question. There is not even any indication of internal work being done. The condition of the engine was determined by compression check and the seven month possession is not indicative of work being done either--a worn engine is a worn engine, regardless of how long it sits in a particular garage or its ancillary components are tinkered with.
The fact the engine failed on his watch may or may not be relevant--only a complete tear down and inspection will determine that, and this should be the first step, after a clear understanding between the two parties is reached.
L.J.
Old 11-24-2009, 10:07 AM
Dixie Region R Gruppe
w21055's Avatar
Well looks like it is for sale.
1973 porsche 911t/ a half
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 11-24-2009, 10:10 AM
what's wrong with this picture....
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 11-24-2009, 10:14 AM
mca mca is offline
mca's Avatar
bizarre
Old 11-24-2009, 10:24 AM
Originally Posted by johnm1469 View Post
this is the car!! bought for 5k/have 5k in/with another 5 k in it is she worth 15 k???john
He should probably edit this post if he's asking $18K with a seized engine.
L.J.
Old 11-24-2009, 10:38 AM
As, I novice I'll chime in just the same. Jury still out until the engine is inspected. No oil, no pressure should result in main bearing failure, low oil pressure, restrictions usually take a rod bearing. I bought my 72 S some time ago with a seized motor, ended up being a chain ramp end lodged in the intermediate shaft gear. The car looks to have had MFI, so should be an earlier 73 or ?
Stay calm. If you know anything about engines, be there when it comes down, if you don't know anything find a friend that does. Good luck, the car looks worthwhile to invest the extra money in it. Enjoy and have a Happy Thanksgiving.
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 11-24-2009, 10:44 AM
There might be more to this story than meets the eye
Sean
NASA GTS2
Old 11-24-2009, 10:49 AM
