Installing a 3.2 in an older car
I am working on a '74 911 and have an '86 3.2 engine and transaxle that I am going to install.
I know that a lot of you have done this.
Do any of you have detailed pictures of your engine compartment wiring and fuel plumbing before you installed the engine?
If so, please share your know how on this conversion.
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 12-27-2009, 07:08 AM
DUK DUK is offline
DUK's Avatar
Here's a good place to start... 3.2 in 78 SC help
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 12-27-2009, 08:50 AM
Thanks DUK.
Has anyone found any other threads on this subject?
Dale
Old 12-28-2009, 07:16 AM
IROC's Avatar
This may help:
Index for Marc's 2.7 to 3.2 Conversion
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 12-28-2009, 09:13 AM
ALXinNZ's Avatar
Hi
I am 99% through the same project. 3.2 into a 74 shell.
The above post by IROC is all you need.
I also added a relay to the fuel pump just for added safety on the DME relay.
Great feeling when it fires into life!!
My issue now is the battery not charging, and i have a back feed from pin 2 red wire ( 14 pin plug ) to alternator that is keeping the idle control valve powered up when ignition is off. scratching my head at moment but it will be fine soon i am sure.
The people on this forum are awesome and very helpful.
Regards
Alex
ps: if you have specific questions about it just pm me Il see what I can do to help chances are you will be fine tho!
Old 12-28-2009, 06:53 PM
Hello again:
From 77 thru 83???? the 911 had two fuel pumps??
Does the 74 only have one?, and it is located on the right side right near the torque tube?
Old 12-29-2009, 11:17 AM
sjf911's Avatar
Originally Posted by daleflesburg View Post
Hello again:
Only the 930 had 2 fuel pumps.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 12-29-2009, 11:48 AM
There is a volume and pressure difference between CIS and Motronic fuel pumps.
Bruce
Old 12-29-2009, 12:04 PM
ALXinNZ's Avatar
I opted to change to a 3.2 pump on the front cross member. I have read that the standard set up is fine but I am not so sure. It won't cost you anything to try it out with the standard set up. Just keep in mind that you may have to update this area if it doesn't work well.
Also remember to check for full throttle when the engine is in and all the linkages are on, This is a problem that some have and it can be a big difference in performance.
Old 12-29-2009, 05:26 PM
You want to take the lock nut off the accelerator to the engine console at the console because you cannot adjust the accelerator with the lock nut in the car. With the nut off you can bend the linkage at the trans to get it off and tighten or loosen as needed by turning at the trans.
Bruce
Old 12-29-2009, 06:21 PM
