Engine grille painting ?
Hello. I am in the process of pulling off my engine lid grille so I can repaint it. My question is should I prime it? I'm going to use Rustoleum satin black for the respray.
Thanks,
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 01-03-2010, 04:29 PM
GothingNC's Avatar
Hope this thread helps
Painting Grill on Rear Lid
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 01-03-2010, 04:48 PM
Senior Advisor
James Brown's Avatar
it's plastic so no need to prime, just make sure it's clean. There is a plastic paint that I have used for lawn furnature. it holds up well and really sticks to plastic.
08 Cayenne Turbo
Old 01-03-2010, 04:50 PM
What James said. Also Krylon makes a plastic specific paint. I'd go with one of those.
O2 In Sully We Believe
Old 01-03-2010, 04:53 PM
Thanks everyone. Thats exactly what I was looking for.
Chris
Chris
95 993 C2
Old 01-03-2010, 04:58 PM
SCWDP911's Avatar
which color and please post pics
Shane
- 1984 928S
Old 01-03-2010, 05:27 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I use rustoleum semi gloss black on mine....I wanted a little more sheen than factory satin finish...holds up just fine. Mine has been done 3 years...still looks as good as the day I did it.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 01-03-2010, 05:29 PM
Meka's Avatar
I have painted a couple grills. I have had the best luck using Bulldog Adhesion Promoter then top coated with a SEM product that is made for use on exterior plastics. Comes in semi, flat and gloss.
Both products are available in clicker can. Most auto paint shops will stock both products.
1984 Carrera
Old 01-03-2010, 07:54 PM
AutoBahned
RWebb's Avatar
you like the Bulldog better than the SEM stuff?
Old 01-03-2010, 09:01 PM
Meka's Avatar
I have never used SEM adhesion promoter. I am not even sure they have such a product. I have used the Bulldog promoter for years with very good success.
I have used SEM's paints on plastics, vinyl, leather and carpet and I am always amazed how well their products work.
The Bulldog promoter before SEM's paint has always worked well for me.
As far as the Bulldog before any other paint or coating I would definitely do a test panel. If the products are not compatible you will know in about five minutes.
1984 Carrera
Old 01-03-2010, 09:22 PM
Formerly known as Syzygy
Canada Kev's Avatar
SEM does have an adhesion promoter. I agree with the comment on SEM's products working well. I have never had a problem. Like any painting, prep is key. Do a light scuff with a Scotch pad blow or wipe off any dust and other loose crud, spray the adhesion promoter and let flash and spray the colour.
Kevin
Old 01-03-2010, 10:11 PM
