Tips on installing new carpet?
I'm re-doing the interior of my 911 hotrod. I decided to be a little different and went with light gray German squareweave. Tony at Autobahn is a Master craftsman and the carpets are stunning!
The interior is stripped with NO backseat. I would like to install some type of sound deadening before carpet goes in. I'm having some hearing problems (400+ Grateful Dead shows) and would like to keep the engine sounds outside of the car, not inside. Any suggestions....Dynomat, B-Quiet, lizard skin etc? Any tips on installation? What type of glue....3M? Certainly don't want to mess these beauties up! Thanks for any help! |
i use secondskin products and i am happy with the results. they have a few that can aide in your application but how many is up to you. for starters, and at a minimum, get some of this:
Damplifier Pro - Acoustic Vibration Dampening Mat that is a vibration damper and it will do a lot to stop noise. use it on all large (or medium) flat metal surfaces like the floor pan, rear parcel shelf, rear seats, doors, etc. it has it's own adhesive so no extra glue is required. the next step you can go one of two ways depending on what you want to spend and how much you want to work. full out would be some ll and heatwave but you can use one or the other and get good results. Luxury Liner - Acoustic Noise Barrier and Insulation Barrier Heat Wave - Acoustic Thermal Insulation and Engine Insulation Material if only using one of the above you can go with the pro version (thicker) but if using both it will be too thick if both are pro. you can see how i did the doors and the rear parcel shelf in the thread below. i will be doing more of the interior in the spring. http://forums.pelicanparts.com/porsche-911-technical-forum/495273-new-audio-install.html as far as installing the carpet... well the only real tip i have found in searching here would be to lay out the old in pattern and then put the new on top of it. you won't mix up pieces and you will know exactly where everything goes. i would use some 3m super90 glue. normally i use the 77 but from what i have seen you need some pretty strong bonds on certain carpet connections so go with the 90, but be sure to follow the directions. |
Thanks!
Second skin looks like quality stuff. I'll get a sample of it and compare it to Dynamat. I don't want to get to thick on the underlayment or the carpet won't fit right. That's quite a stereo install thread you did! Very nice. Thanks again for the info. Anyone else got any tips? |
Just did another search using more specific wordage! Found some informative threads.
Thanks |
+1, and 9ball thanks for the sound equipment links, good to know where to get quality stuff. Take care, O- |
my pleasure. if you or anyone else has any audio-related questions feel free to pm me.
If you have a heat gun, use that because some spots take a lot of pulling and stretching and the heat gun makes the carpet more pliable and easier to work with. A hair dryer will work as well.
Glue: 3M for sure, but be carefull with the real sticky stuff, because sometimes you will need to remove the carpet real fast due to it not being in the right spot. Very sharp razor blade and scissors. A very large/ long socket which I found to work awesome when pushing the carpet into tight areas. It also works great in smoothing the carpet in places as it slides very easily over the carpet. I piece of cardboard which is used to block over-spray when you have to spray the adhesive in certain parts of the car. A hand cleaner to clean hands during the job as you will get glue on them and you don't want to transfer glue on new carpet pieces. Search RS carpet install as there are some great threads on installing carpet sets, and even though you are not installing that type, the process is kind of the same. |
Thanks tobluforu. I've got to get the sound deadening ordered and do the install. Staring at the carpet in the box is cool, but I wanna see it IN THE CAR!
I did both Damplifier and Luxury, I figured I would regret not adding the extra protection later. I am happy with both products.
Here is pic before the Luxury... http://forums.pelicanparts.com/uploa...1263202947.jpg |
I've been reading many of these posts about using vibration damping material and I've had a nagging question - has anyone definitively seen significant noise reduction using Constrained Layer Damping material such as Damplifier? The reason I ask is that I've had a fair amount of experience over the years trying to design damping into military airborne electronics in an effort to reduce vibrations. I looked hard at CLD materials and learned that it is VERY difficult to design CLD into your particular structure and actually get results. The problem is that CLD is not only dependent on the size, thickness and material of your damping sheet, your particular panel and the adhesive layer, but the viscoelastic properties of the adhesive layer also make the problem dependent on temperature and the frequency you are attempting to dampen. So in my experience simply slapping some CLD material on a panel is very hit-and-miss.
Porsche Head,
Did you finish with the Luxury Liner install and have you taken it for a drive yet? If not, please report back if you notice any decrease in noise levels from the back of the car... Thanks. |
Doug
You've made some good points in your post and I'm sure you know what you're talking about but... I've used Dynamat in both of my cars and it definitely makes a difference. Having said that I haven't tested it with a sound level device so I have no idea how effective it really is. Our cars are getting old and often the OEM sound deadening felts/mats are rotten or past their best. When I stripped my car the felts/mats had deteriorated so bad that I didn't really have any other options. Also... I think it's easier and neater to use something like this rather than glue and old fashioned felt. |
doug
damplifier, damp pro, dynamat and similar cld products are vibration dampers not noise blockers. their job is to reduce vibration in large sheets of metal, and while most quality products achieve this goal the end user hears less noise and thinks that they are blocking noise as well. most people, like cliff and myself, were misinformed over the years as to it's intended use and application methods. in one of my cars i applied dynamat xtreme just as he did. http://i15.photobucket.com/albums/a3...s/000_3732.jpg in reality you only need to cover the panels that will resonate from road vibrations instead of a layer over everything. that really comes down to just the large, flat areas of metal. places that have bends or a pattern, if you will, of raised portions, will not have the same acoustical qualities and can be left on their own. a perfect example of this is a modern trunklid. here is a shot of the one i did for example. http://i15.photobucket.com/albums/a3...s/000_3714.jpg i covered the entire lid when all i really needed to do would be the triangle shaped parts. the green arrows below are what needed to be covered and the red arrows point to what would have been fine on it's own. http://i15.photobucket.com/albums/a3...s/trunklid.jpg i have spoken with the guys at SSA as well as a few other companies and they really seem to know their stuff. their products were designed to be used in a car, and if applied properly they do their job well. if noise reduction is your final goal you can't simply just slap some cld and call it a day as that is not the purpose of cld. you really need to add something on top of it like luxury liner or heatwave. these are the items that need to be a blanket if you will and cover everything, including having their seams sealed. these are the noise blockers/absorbers and when applied correctly really do their job well. one without the other will work to a point but when used in conjustion they really perform well. of course if you want to go all out you can get some lead sheets as they will block external noise the best but they also weigh a ton. |
I do have one concern.....the thickness of whatever product I end up using may affect how the carpet lays down and fits. If I use two layers of deadening before the carpet, the carpet may not fit like it's suppose to. The carpet is cut and bound already.
that is why i suggested that if using 2 materials you do not get the "pro" version. i spoke with ssa and they have had a lot of 911-related questions. their best solution would be to use damplifier and then heatwave on the rear seats and then damp/luxury liner on the floors. the heatwave is not as good as the luxury liner at reducing/absorbing noise but it is better at dealing with heat.
i recently did the rear parcel shelf and upper seat backs with damp pro and some closed cell foam i had left over. the foam was not the best solution to my "problem" but i had some on hand and didn't want to throw it out. once both were installed i had no problems putting the parcel shelf cover back on. since this area will see the most "noise" from the engine and has lots of flat metal area i covered the whole thing. http://i15.photobucket.com/albums/a3...o/100_4881.jpg http://i15.photobucket.com/albums/a3...o/100_4884.jpg http://i15.photobucket.com/albums/a3...o/100_4885.jpg http://i15.photobucket.com/albums/a3...o/100_4886.jpg this is the factory piece i removed and then reinstalled with no problems. it is the thick rubber with a thick insulation-like material under. the insulation can easily be compressed so it was not a problem. http://i15.photobucket.com/albums/a3...o/100_4887.jpg |
Kurt (KNS),
sorry the car went back on the lift for a big brake kit, steering rebuild etc. so it has not seen any road time. I can tell you this, I ran the car while on stands and it was noticeably better. If you knock on the panels from the inside it is a dead sound vs. a solid think so I am very anxious to do a road test when I am done. It may seem like overkill to do both Damplifier and Luxury but my car was load with the dual out Dansk. The extra weight (~20 lbs total) will be offset by my CF hoof and new Braille battery, beside I have a Rotrex supercharger also waiting to go in. I don't want to do all of that then realize I needed to pull the carpet. I was going to go full lightweight like some of the folks here but after driving it around for a while without any dampening or carpet I was done with that, I wanted a slightly more modern upgrade feel. I promise I will do some inside recordings when I am back on the road even if only for future Pelican folks because I think it important to think out exactly what you are looking for in your ride and customize it to-wards that. Cliff |
I also have a dual-out Dansk. It sounds GREAT, but with no engine compartment insulation and nothing inside the car (yet) in sounds like I'm inside a snare drum! With my bad hearing, it actually hurts!
Heat has not been a big factor even with my car not having A/C. The noise is #1 concern. So....I would be more inclined to want to stop vibrations>noise than insulate for heat. |
A tip for glue: yes the 3M spray stuff is great for the majority but pick up some brush-on contact cement for trickier/stubborn places where you really need a good stick.
When I installed my RS carpet I installed foam like material that someone on this board recommended. It is very light weight, comes in different thicknesses and is used to deaden sound in airplanes. It was pretty cheap, and one side has adhesive. I'm actually pretty impressed at how much it deadens the sound. I drove my car without any carpet and the asphalt in the rear, and it was pretty unbearable with a 2 out M&K muffler. Now its even quieter then having the stock carpet, and the RS carpet is much thinner then the stock one so this stuff works pretty damn well. Now if I could only remember what it's called, but if you search out the rs carpet installs, it's in one of the threads.
| All times are GMT -8. The time now is 10:10 AM. |
