Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
911sc wiring to starter motor...i lost my notes!
does anyone know the how the wiring is done on a stock bosch starter on my 78SC?
specifically, which is the ground and which is the hot? i think the ground is the wire towards the quarter and the red is on the big bolt closest to the transmission?
thanks
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 01-09-2010, 01:44 PM
The black wire of the chassis is the battery.
The red from the engine and the black from the battery go together on the 8mm stud of the bendix.
The solid yellow goes to the top slip on connection
The yellow/blue stripe goes to the lower slip on connector
Bruce.
Old 01-09-2010, 02:14 PM
Black and Blue
Kemo's Avatar
thanks Bruce!
i just have this aversion to clamping a RED wire and a BLACK wire together. intuitively, thats "ground to hot".
thanks again, you saved the night. putting engine back in after 1st engine drop
so far so good.
Kemo
Old 01-09-2010, 03:13 PM
You ll do good. What I do is do all electrics, clutch, all fuel, then all oil. I put it together that way, but I still forget the starter at times
Bruce
Old 01-09-2010, 05:56 PM
Almost Banned Once
sc_rufctr's Avatar
This is how my 78 is set-up but I've added a relay... It's worth doing so save your ignition switch.
The thick cable going to the left goes to the relay.
- Peter
Old 01-09-2010, 07:00 PM
