Distributor for CIS converted to carbs engine?
Hey all. I've got a set of Zenith 40TIN carbs (34mm venturis) going on my 83 euro 3.0. Just wondering if the cis distributor will cut it for the carbs.
Thanks-
Craig Backer
Old 01-11-2010, 09:45 PM
Almost Banned Once
sc_rufctr's Avatar
I'm not sure what you mean... You don't need anything from the CIS to run carbs.
Do you mean the fuel pump?
- Peter
Old 01-11-2010, 09:55 PM
I meant the ignition distributor which was and is on the cis engine - different distributors are curved differently.
Old 01-11-2010, 10:00 PM
Almost Banned Once
sc_rufctr's Avatar
You can get it recurved for use with Carbs... There are members here who do this.
They should chime in.
- Peter
Old 01-11-2010, 10:07 PM
I know but do I need to?
Old 01-11-2010, 10:08 PM
Almost Banned Once
sc_rufctr's Avatar
Yes.
IMO... To get the most from your carbs you should get your distributor re curved.
Can you post some pics of your Zenith 40TIN carbs. I'm curious. Were did you get them?
- Peter
Old 01-11-2010, 10:26 PM
haycait911's Avatar
you can run your CIS dizzy just fine, but you may be leaving a little on the table. I've been running a stock SC dizzy in this engine:
3.0 dyno day - a pleasant surprise
as you can see, it works. BUT, I will be getting a dizzy re-curved for it this season. I would leave it till one of the later things to do. sort out everything else first, it's kind of a crowning touch. FWIW
Old 01-11-2010, 10:37 PM
my 2.7 RS dizzy, 10deg initial/35deg total works great with 8.5:1 compression
CIS dizzy is for smog afai know
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-11-2010, 10:39 PM
Senior Advisor
James Brown's Avatar
I did the same thinh Haycait911 did, just remove ALL the vacuum hoses and run mechanical advance. Mine comes full in around 3K and is a little advanced 3˚BTDC on start but you can fiddle with that after you get the thing running. Jerry West does a good job of curving for 3.0 carb engines but for now, it will work good, in fact, mine works soooo good that I don't want to chang it! But will because there is always something in there for the rear wheels. Concentrate on the carbs now.
08 Cayenne Turbo
Old 01-11-2010, 11:03 PM
brads911sc's Avatar
I had mine rebuilt, recurved and vacuum advance removed by Barry Hershon. Not cheap but a GREAT job. IMHO, I'd say it was definitely worth it. If your car has 100k miles on it Id take the time to have the bushings in your distributor changed. They will def need it. 5 degrees BTDC at idle 30 Degrees at 3000 RPM is what Richard at PMO recomends for his kits.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 01-12-2010, 04:12 AM
Scott R's Avatar
I drove around for a while with the stock CIS distributor on my Webers, it's kind of pokey compared to re-curved distributor I have in there now. But it does work.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-12-2010, 06:54 AM
Somatic Negative Optimist
Gunter's Avatar
Question
Thanks-
Craig Backer
Zenith carbs don't have the best reputation..................however, if you install them, I suggest you either have the distributor recurved to run without vacuum or swap your 016 ignition distributor to an earlier 001 with vac advance only.
The 0 237 306 001 has a better curve because the '78-'79 SC's had no Lambda.
You also have to deal with the fuel pump.
The CIS fuel pump pressure is way too high for carbs. Switch to one with lower pressure or install a reducer of sorts.
Why are you going with Zenith carbs?
I would consider a well-maintained CIS more reliable than Zenith's.
What cams do you have?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-12-2010, 11:18 AM
Excellent advice!!
Stock SC distributors are quite lazy and really need the help, especially with carbs or MFI.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-12-2010, 12:56 PM
Carrerax's Avatar
Craig, did you get the velocity stacks for the zeniths yet? They were shipped several days ago. For the distributor I would also suggest that you have it recurved. Im shipping mine to Rennsport Systems to be done.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 01-12-2010, 01:23 PM
Senior Advisor
I installed Zeniths with new ventures, idle and main jets on a 3.0 and it screams! With stock cams and stock dizzy. More hp's are in there but for now, it is quick enough. Getting to the limit of the suspension. cold starts are great, sound is awesome, fuel mileage is down some but thats ok. The Zeniths are a great carb if set up correctly and pull right up to redline. I'm totally happy and the cost is way cheaper than rebuilding a balky CIS system or going with Webers/PMO's. Looks great also!!
08 Cayenne Turbo
Old 01-12-2010, 06:28 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
how much is not cheap?
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 01-12-2010, 08:30 PM
And mine...
Just got her on the road today. Euro 3.0 (9.8:1 cr w/ large port heads), same carb setup as James Brown, 7.31:1, stock cis distributor and backdated exhaust. It's definitely way more of a hoot to drive than with cis! Noticeably faster and sounds great!
Old 01-12-2010, 08:51 PM
oneblueyedog's Avatar
Barry Herschon Recurved my distributor too. I'm well pleased. It's been 5 years of great fun.
78SC coupe, Silver Metallic
Old 01-12-2010, 09:02 PM
Senior Advisor
congrats fastbacker, looking good! they are a hoot to drive!
08 Cayenne Turbo
Old 01-12-2010, 09:38 PM
Gunter's Avatar
I remember the Zenith carbs in the VW Buses as a PITA.
Sounds like they may have improved?
Using carbs and a more aggressive cam-profile without re-curving the 30-year old distributor means maximum performance is not achived.
Re-curving to run without vacuum would be $400.- plus. It takes a lot of repeated dismantling and tweeking weights and springs.
Old 01-13-2010, 09:30 AM
